Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Input and Output Power of motor in transient report
    • easytoh8
      Hi.
      I was looking at various Ansys maxwell papers and I noticed one in which I saw it was possible to get graph of Input/Output power of motor like in below picture. Motor was made in RMXprt and converted to Maxwell 2D.
    • Navya C
      Hi @easytoh8 You can from the expressions for input power and output power(depending on the machine you are using) under output variables and then these will appear in Rectangular plot>output variables.
      Then you can plot these.
      Regards Navya
    • easytoh8
      Hi!
      So from the "Output Variables" that are available in my pictures below I have to form equation for input and output power. So that will then be plottable....
    • Navya C
      Hi @easytoh8 You need to right-click on the results and select output variables. On the popup window, you will be able to form the expressions using the Category and Quantity tabs and assign a name to it and Add.
      The below screenshot is only for illustration.
      Then you can see these in the rectangular plot>output variables
      Regards Navya
    • easytoh8
      Thanks, this works!
Viewing 4 reply threads
