Platform
Platform
Input File for Transient Simulation on SLURM
    • Akash564
      Hello, I'm trying to submit a batch job for a transient simulation on SLURM. I've worked with steady simulations. But, I'm confused about the commands for transient simulations. How do I write case and data files for certain number of time-steps? The following commands are for the steady simualtion. How can I modify it for transient simulations?
      /file/set-batch-options
      /file/read-case test.cas
      /solve/initialize/initialize/
      /solve/iterate 500
      /file/write-case-data test%i.cas.gz
      /exit yes
      Thanks!
    • Keyur Kanade
      You can use auto save option. You can use following commands after initialization. Please make sure you give appropriate inputs to all these commands.
      /file/auto-save data-frequency
      /file/auto-save append-file-name-with time-step
      /solve/set/time-step
      /solve/dual-time-iterate
      Keyur
      • Akash564
        Thank you Keyur!
