May 2, 2023 at 9:18 am
Anirudh Thantry
SubscriberHow can input parameters be used in function definition for pressure loads in Static structural analysis?
May 2, 2023 at 3:23 pm
Armin_A
SubscriberHi Anirudh,
Once you defined Pressure under Static Structural, under Details toolbar, you can select the arrow beside Magnitude and then select "Function". Next, you can input your pressure function in a tabular form under Tabular Data.
May 2, 2023 at 3:57 pm
Anirudh Thantry
SubscriberI don't wanna input value, instead i wanna input a parameter that i have created (the ones in the parameter set) in the function expression. How can this be done?
May 2, 2023 at 4:36 pm
Armin_A
SubscriberI see. I’m not sure about the answer but please see if the link below on all supported ways of defining a Magnitude is helpful to you: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/wb_sim/ds_spec_load_values.html
This video might also be helpful on the use of parameters: Analyzing more than One Design - Lesson 3 - ANSYS Innovation Courses
3311
2469
