May 26, 2023 at 12:26 pm
Ahmet Seckin Hezarfen
SubscriberI am trying to make a simulation to observe the optomechanical effects in the ring resonator by changing the input powers. I am using a mode source in my design but I coulnt find a way to change the input power. Its like, I want to change the pump power from 0mW to 10mW and see the transmission resonance shift. Can you please help me about it?
Best Regards,
Seckin
May 26, 2023 at 6:25 pm
Guilin Sun
Ansys EmployeeYou can modify the mode amplitude. I think a similar question and answer can be found here: Lumerical varFDTD mode source specifications
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5162
3275
2453
