June 15, 2020 at 10:50 am
jungsungsuk
SubscriberHello.
Can I input the volumetric heat flux in CFX domain?
I want to consider heat exchanger with only one fluid, so I have to input the heat flux data from the experimental results.
I have the total heat flux data in dimension [kW].
I want to input the data to entire fluid domain in dimension [kW/m^3]
Can I input the data like that? How can I?
Thank you.
June 18, 2020 at 4:16 pm
Surya Deb
Ansys EmployeeHello,
I am guessing you want to provide a Volumetric Heat Source and not a Surface Heat Flux.
You can make use of Subdomain Approach in CFX. Once you create a subdomain, you can then provide your Energy Source.
In CFX, you can also use Profiles from Tools->Initialize Profile Data.
You can find more information in CFX documentation for both Subdomain and Profiles.
SD
June 20, 2020 at 11:31 am
jungsungsuk
SubscriberThank you for your reply.
I have applied the Subdomain and Energy source to the domain, but in the CFD-post, its temperature didn't vary.
I think the Energy source didn't applied normally,
These are the settings I have inserted. I there any problem inserting the subdomain and heat source?
Thank you in advance.
3678
2552
1751
1232
584
