August 1, 2019 at 3:34 pm
rick825
SubscriberHi Everyone,
I have developed a geometry and mesh for a 2D static structural analysis. The attached Workbench schematic reflects my completed stand-alone mesh component that I would like to insert into the static structural component. I figured out how to import the geometry but not the mesh into the static structural component
. Could someone help me with this?
Thank You!!!!
August 1, 2019 at 5:10 pm
Sandeep Medikonda
Ansys EmployeeWhy not import the geometry and mesh it directly in Static Structural? You should've all the same features available?
August 1, 2019 at 6:33 pm
rick825
SubscriberI had hoped to keep the geometry and meshing distinct from analysis issues. I spent much time working to generate a good mesh and was hoping, since mesh is a component, to add it to analysis later. I'm basically looking for a way to utilize the work I already completed and move forward.
Thank You for your response!!!!
August 1, 2019 at 10:45 pm
SubscriberThe Mesh component in the Toolbox is for CFD meshing. You made a mistake using that for meshing instead of a Static Structural analysis system. Workbench will not link a Mesh component to a Static Structural model.
It is possible is to have one Mechanical Model, and multiple Static Structural models. This is what you should do.
August 1, 2019 at 11:38 pm
rick825
SubscriberYes this is exactly what I am looking for. Thank You!!!!
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2518
2064
1279
1094
456
