October 19, 2023 at 4:56 pm
Aitana Cano
SubscriberI am simulating with Maxwell (DC conduction) how current is distributed through a structure of metal-semiconductor(Ge)-metal, like the one of the image. I would like to add a contact resistance between the metal layers and the semiconductor one, so I would like to know if there is a simple way of doing this, for example by asigning a resistance to that interface. At the moment I have only thought of adding another intermediate layer with a resistivity equivalent to this contact resistance. However, I want to try different geometries for the metal contact, for what this solution is not practical.
Thank you in advance :)
October 20, 2023 at 11:04 am
Reshmi Raghavan
Ansys EmployeeHello Aitana,
In Maxwell eddy current sovler and mangetic transient solver we have a boundary condition called as resistive sheet, which is used to specify the contact resistance value . The face in contact with the two parts can be selected and the resistive boundary condition can be assigned. The value of the contact resistance can be mentioned while assisgning the boundary condition.
In the case of DC conduction solver the method you have mentioned has to be followed( modelling additional part with updated material proeprty)
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
