November 26, 2019 at 10:42 am
Newbie
SubscriberHello
At the beggining, I'd like to apologize if my question is in the wrong section.
My problem is that I cannot insert one object into another in Design Modeler. I can use Freez, but then in Mechanical freezed things did not work. When I unfreeze object when it's in another object (for ex. sphere in a sphere), they merge into one. I can create external sphere to be dome (with no interior, so it cannot merge with inner sphere), but I care for external sphere to be full, not only a dome.
November 27, 2019 at 12:20 am
tsiriaks
Ansys EmployeeI'd recommend to try posting this question in Pre and Post Processing -> Geometry and CAD section as you may get more attention on there.
Thanks,
Win
November 29, 2019 at 1:38 pm
Ansys EmployeeWithout seeing the model it's hard to say. Best guess is that you've not split one body with the other.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5180
3275
2455
