April 1, 2018 at 8:59 pm
hgsdvd
SubscriberHello Guys,
I always appreciate your help. I want to know how to insert the the thermal properties such as Specific Heat and Thermal Conductivity with respect to temperature.
I could insert a specific value while I wanted was with respect to temperature.
Thanks
April 3, 2018 at 4:56 pm
raul.raghav
SubscriberIf you have a formula for thermal conductivity with respect to temperature, i.e. k = f(T): you can create an expression, say "kFunction" and define the equation for the themal conductivity. Now you can define this "kFunction" as the Thermal Conductivity in the Transport Properties of the solid.
- The topic ‘Inserting thermal properties of solid into ANSYS-CFX’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
