June 23, 2023 at 3:36 pm
June 26, 2023 at 10:51 am
Aniket
Ansys Employeeyou can click exit, it seems there are some warnings and errors you can check them as indicated in image.
-Aniket
June 26, 2023 at 4:47 pm
June 26, 2023 at 4:58 pm
Aniket
Ansys Employeethere doesn't seem any. Is there any issue you are facing after installation?
-Aniket
June 26, 2023 at 5:05 pm
bozidarperinac
Subscriberhttps://drive.google.com/file/d/12h69cUXq0yXrgRukDrF9lB3PvO41CzK-/view?usp=sharing
yes. i open workbench ,make static structural(something very basic,a roller fixed on one end and force on other end). mesh works good. for solution i put basic total deformation. then i press solve. solver goes to 10% and i get this error message.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2967
1449
1322
