LS Dyna
LS Dyna
Install Ansys LS-DYNA on ubuntu 20.04
    • RemiDelaunay
      I installed Ls-dyna and licence manager on ubuntu 20.04. However when I try using LS-dyna (with the licence manager running) I have the following error :
      *** License problem ***
       Local license:
       *** Error Environment variable LSTC_FILE not set!
       *** Error 70022 (OTH+22)
         Please contact
          Livermore Software Technology, LLC
          Tel: 844.Go.Ansys (844.462.6797)
          Email: [email protected]
      Can you help with this ?
      @tslavik and
      @ekostson
      Thank you
      Remi
    • TrentE
      If you were given a file named LSTC_FILE, then you can place it in the directory with the LSDYNA executable and it should be able to find it. Or you can set an environment named LSTC_FILE that points to the license file named LSTC_FILE.
      If you have an ANSYS-LSDYNA license, then you'll need to set the variables differently. For example
      setenv LSTC_LICENSE ANSYS
      setenv LSTC_LICENSE_SERVERHOSTNAME-OF-SERVER
    • RemiDelaunay
      Hi I have an ANSYS-LSDYNA licence. I set the variables as described and now I have the following error :
      ******** UNEXPECTED ERROR - NETWORK TASK CONTROL INCONSISTENCY *******
      Please contact
      Email: LstSupport@ansys.com
      Thank you
      Remi
    • RemiDelaunay
      UPDATE : I added a lstc_file in my binary folder as describe here : http://www.lstc.com/download#section2 but now I got the following error :
      Local license:
      *** Error This version (LS-DYNA) is not included in the current license key
      Network license:
      *** Error License client cannot find any servers to talk to.
      Servers may be down, not ready, or the wrong version.
      Please contact
      I don't understand because I started the licence manager and I only have one version of lsdyna.
      Best
      Remi
    • Jim Day
      Remi I see there's been no traffic on this thread since May 28. Has the problem been resolved? If not, my question to you would be where (from whom) did you obtain your LSTC_FILE and what version of LS-DYNA are you attempting to run?
Viewing 4 reply threads
