December 7, 2020 at 11:14 pm
Arnopov
SubscriberHello,
I'm trying to help a student, but cannot make sense of the install.err file.
At this stage, my recommendation would be to uninstall, and retry, perhaps with 19R3, but is there something glaring in this install.err??
(It's quite long, I think it documents several attempts)
December 8, 2020 at 9:24 pmANSYS_MMadore
Ansys EmployeePlease uninstall, then delete the installation directory. Next, extract the downloaded zip file and run the setup.exe from within the extracted files. They appear to have tried installing from within the zip file, which results in failure.nnThanksnMattnDecember 8, 2020 at 10:33 pmArnopov
SubscriberSuper, thanks a lot!nDecember 11, 2020 at 5:30 pmArnopov
SubscriberJust to confirm, the students followed the correct procedure (i.e. unzip first!) and successfully installed it.nVery grateful, thanksnViewing 3 reply threads- The topic ‘install.err, what is going wrong?’ is closed to new replies.
Trending discussions- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
- Fluent Meshing Error (Scope To: edges/faces and edges)
8808
4658
3153
1680
1470
