October 10, 2022 at 6:46 pm
simsek8
SubscriberThere is a stubborn error I encounter when I try to install the software.
Here is the install.err file:
>>>---------------------------------------> Ansys installation: Pzt Eki 10 21:08:54 2022 Revision: 2022 R2 ###### Error ####### Error extracting C:\Users\emre\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\additive_cl\WINX64.7z: '"C:\Users\emre\AppData\Local\Temp\ans_install_tmp8704\7zip\7z.exe" x -aoa -bb1 "C:\Users\emre\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\additive_cl\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s): Unknown error Exit Code: 2 >>>--------------------------------------->
>>>---------------------------------------> Ansys installation: Pzt Eki 10 21:31:55 2022 Revision: 2022 R2 ###### Error ####### Error executing configuration script 'C:\Users\emre\AppData\Local\Temp\ans_install_tmp14192\config\AnsConfigWB.tcl' '"C:\Users\emre\AppData\Local\Temp\ans_install_tmp14192\tcl\bin\winx64\tclsh.exe" "C:\Users\emre\AppData\Local\Temp\ans_install_tmp14192\config\AnsConfigWB.tcl" -installdir "C:\Program Files\ANSYS Inc\ANSYS Student" -rev 222 -dotrev 2022 R2 -scripttosource "C:\Users\emre\AppData\Local\Temp\ans_install_tmp14192\config\ConfigCommon.tcl" -sourcedir "C:\Users\emre\AppData\Local\Temp\ans_install_tmp14192" -os_lang en-us -install ' terminated after 1 attempts with the following error(s): Unknown error Exit Code: 1 Graphics Driver Verification and Setup Error. >>>--------------------------------------->
Emre
October 10, 2022 at 8:13 pm
SubscriberDid you extract the files from the .zip file first, then open a Windows Explorer window on the new folder that was unpacked from the archive? You can' run the setup.exe from inside the zip file.
Did you Run As Administrator the setup.exe?
October 10, 2022 at 8:21 pm
simsek8
SubscriberThanks for the quick reply. Yes, I extracted the files from .zip first. After that, I installed some exe files inside of prereq sub-folder. Finally, I right-clicked setup.exe and clicked run as administrator.
I also want to elaborate on my pc and installation history. I was using Ansys Student Edition without any problem. Today I realised there is a licence problem. Thus I uninstalled and downloaded a new installation file from Ansys Student webpage.
Best regards,
Emre -
October 10, 2022 at 8:25 pm
SubscriberOpen a Windows Explorer and in the address bar, type %appdata% and hit Enter.
You will be in the Roaming folder and will see an ANSYS folder. Delete that folder. Then go up a level then down into the Local folder where you will see another ANSYS folder. Delete that folder.
Now go to C:\Program Files and delete the ANSYS Inc folder.
Restart your PC then try to install ANSYS one more time.
October 10, 2022 at 8:52 pm
simsek8
SubscriberThanks, I did as you said. Unfortunately, it gives a similar error.
Ansys installation: Pzt Eki 10 23:50:11 2022
Revision: 2022 R2###### Error #######
Error executing configuration script 'C:\Users\emre\AppData\Local\Temp\ans_install_tmp3740\config\AnsConfigWB.tcl'
'"C:\Users\emre\AppData\Local\Temp\ans_install_tmp3740\tcl\bin\winx64\tclsh.exe" "C:\Users\emre\AppData\Local\Temp\ans_install_tmp3740\config\AnsConfigWB.tcl" -installdir "C:\Program Files\ANSYS Inc\ANSYS Student" -rev 222 -dotrev 2022 R2 -scripttosource "C:\Users\emre\AppData\Local\Temp\ans_install_tmp3740\config\ConfigCommon.tcl" -sourcedir "C:\Users\emre\AppData\Local\Temp\ans_install_tmp3740" -os_lang en-us -install ' terminated after 1 attempts with the following error(s):
Unknown error
Exit Code: 1
October 10, 2022 at 11:49 pm
SubscriberTry installing the latest Driver for your Graphics Adapter.
October 11, 2022 at 4:25 am
simsek8
SubscriberSince my dedicated graphical driver (AMD Radeon R9 M265X) was broken I have been using my laptop with disabling the dedicated and enabling only on board driver card (Intel HD Graphics 4600). This thing is not new for Ansys products. Because I was using 2021, 2019 or other versions I don't remember and Ansys didn't give any problem.
Emre
November 8, 2022 at 3:26 am
kesav Raj
Here is the install log file:
Start Installation: Tue Nov 8 08:37:28 2022
Revision: 2022 R2
Platform specifics:
Windows
Username of Installer: MSI\KESAV RAK M K
User Has Administrator Privileges
C:\Users\KESAVR~1\AppData\Local\Temp\ans_install_tmp8052\instcore.exe -usetempdir C:\Users\KESAVR~1\AppData\Local\Temp\ans_install_tmp8052 -launchdir D:\ansys -admin
Initial mount directory:
D:\ansys
Installation Directory:
Windows x64
Ansys, Inc. Products
Explicit Dynamics
Autodyn
Fluid Dynamics
CFX (includes CFD-Post)
Chemkin
Energico
Model Fuel Library (Encrypted)
Reaction Workbench
EnSight
FENSAP-ICE
Fluent (includes CFD-Post)
Forte (includes EnSight)
Polyflow (includes CFD-Post)
TurboGrid
Offshore
Aqwa
Structural Mechanics
Mechanical Products
Ansys Geometry Interfaces
Discovery Geometry Interface
SpaceClaim Geometry Interface
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
Extraction: D:\ansys\framewrk\WINX64.7z ...
Extraction: D:\ansys\instcore\tcl\COMMON.TGZ ...
Extraction: D:\ansys\instcore\tcl\WINX64.TGZ ...
Extraction: D:\ansys\instutil\INSTUTIL.7z ...
Extraction: D:\ansys\instcore\tk\COMMON.TGZ ...
Extraction: D:\ansys\instcore\tk\WINX64.TGZ ...
Extraction: D:\ansys\configs\clientlicensing\WINX64.7z ...
Extraction: D:\ansys\clclient\WINX64.7z ...
Extraction: D:\ansys\subs\WINX64.7z ...
Extraction: D:\ansys\autodyn\WINX64.7z ...
Extraction: D:\ansys\addincfg\autodyn\WINX64.7z ...
Extraction: D:\ansys\sgcharts\WINX64.7z ...
Extraction: D:\ansys\fwgfx\WINX64.7z ...
Extraction: D:\ansys\commoninstall\WINX64.7z ...
Extraction: D:\ansys\configs\ansconfigdll\WINX64.7z ...
Extraction: D:\ansys\common\WINX64.7z ...
Extraction: D:\ansys\configs\common\WINX64.7z ...
Extraction: D:\ansys\cpythext\WINX64.7z ...
Extraction: D:\ansys\cpythnew\WINX64.7z ...
Extraction: D:\ansys\cpythcloudext\WINX64.7z ...
Extraction: D:\ansys\hlp\hlpviewer\HLPVIEWER.7z ...
Extraction: D:\ansys\configs\help\WINX64.7z ...
Extraction: D:\ansys\tp\7zip\WINX64.7z ...
Extraction: D:\ansys\tp\angular-nvd3\WINX64.7z ...
Extraction: D:\ansys\tp\angular-ui-context-menu\WINX64.7z ...
Extraction: D:\ansys\tp\angular-ui-tree\WINX64.7z ...
Extraction: D:\ansys\tp\angularjs\WINX64.7z ...
Extraction: D:\ansys\tp\angularjs-slider\WINX64.7z ...
Extraction: D:\ansys\tp\angularUI\WINX64.7z ...
Extraction: D:\ansys\tp\bootstrap\WINX64.7z ...
Extraction: D:\ansys\tp\d3\WINX64.7z ...
Extraction: D:\ansys\tp\ffmpeg\WINX64.7z ...
Extraction: D:\ansys\tp\IntelCompiler\WINX64.7z ...
Extraction: D:\ansys\tp\jquery\WINX64.7z ...
Extraction: D:\ansys\tp\ngInfiniteScroll\WINX64.7z ...
Extraction: D:\ansys\tp\nvd3\WINX64.7z ...
Extraction: D:\ansys\tp\qt\WINX64.7z ...
Extraction: D:\ansys\tp\signalr\WINX64.7z ...
Extraction: D:\ansys\tp\hdf5\WINX64.7z ...
Extraction: D:\ansys\tp\zlib\WINX64.7z ...
Extraction: D:\ansys\tp\openjre\WINX64.7z ...
Extraction: D:\ansys\configs\wb\WINX64.7z ...
Extraction: D:\ansys\addins\WINX64.7z ...
Extraction: D:\ansys\addins\ansoft\WINX64.7z ...
Extraction: D:\ansys\addins\matdes\WINX64.7z ...
Extraction: D:\ansys\addincfg\wb\WINX64.7z ...
Extraction: D:\ansys\corewb\WINX64.7z ...
Extraction: D:\ansys\cads\cadaisol\WINX64.7z ...
Extraction: D:\ansys\cads\cadregistry\WINX64.7z ...
Extraction: D:\ansys\meshing\WINX64.7z ...
Extraction: D:\ansys\blademodeler\WINX64.7z ...
Extraction: D:\ansys\apipsrv\WINX64.7z ...
Extraction: D:\ansys\designmodeler\WINX64.7z ...
Extraction: D:\ansys\syscplg\WINX64.7z ...
Extraction: D:\ansys\mechsrvplg\WINX64.7z ...
Extraction: D:\ansys\rsm\WINX64.7z ...
Extraction: D:\ansys\icemwb\WINX64.7z ...
Extraction: D:\ansys\addincfg\turbosys\WINX64.7z ...
Extraction: D:\ansys\cads\acispara\WINX64.7z ...
Extraction: D:\ansys\sec\WINX64.7z ...
Extraction: D:\ansys\spaceclm\WINX64.7z ...
Extraction: D:\ansys\configs\spaceclm\WINX64.7z ...
Extraction: D:\ansys\ccm\WINX64.7z ...
Extraction: D:\ansys\ecadxltr\WINX64.7z ...
Extraction: D:\ansys\electro\WINX64.7z ...
Extraction: D:\ansys\cads\spatialiop\WINX64.7z ...
Extraction: D:\ansys\aas\WINX64.7z ...
Extraction: D:\ansys\cfxcomon\WINX64.7z ...
Extraction: D:\ansys\addincfg\minerva\WINX64.7z ...
Extraction: D:\ansys\addincfg\granta_gateway\WINX64.7z ...
Extraction: D:\ansys\addins\granta_gateway\WINX64.7z ...
Extraction: D:\ansys\addincfg\granta_selector\WINX64.7z ...
Extraction: D:\ansys\addins\granta_selector\WINX64.7z ...
Extraction: D:\ansys\cads\stride\WINX64.7z ...
Extraction: D:\ansys\cads\hoops\WINX64.7z ...
Extraction: D:\ansys\addins\injmold\WINX64.7z ...
Extraction: D:\ansys\dpf\WINX64.7z ...
Extraction: D:\ansys\tp\intelmkl2020.0.166\WINX64.7z ...
Extraction: D:\ansys\cff\WINX64.7z ...
Extraction: D:\ansys\cfx\WINX64.7z ...
Extraction: D:\ansys\addincfg\cfx\WINX64.7z ...
Extraction: D:\ansys\configs\cfx\WINX64.7z ...
Extraction: D:\ansys\post\WINX64.7z ...
Extraction: D:\ansys\addincfg\cfdpost\WINX64.7z ...
Extraction: D:\ansys\tp\cpprestsdk\WINX64.7z ...
Extraction: D:\ansys\chemkin\WINX64.7z ...
Extraction: D:\ansys\configs\chemkin\WINX64.7z ...
Extraction: D:\ansys\addincfg\chemkin\WINX64.7z ...
Extraction: D:\ansys\tp\intelmkl2021.3.0\WINX64.7z ...
Extraction: D:\ansys\configs\energico\WINX64.7z ...
Extraction: D:\ansys\configs\rdworkbench\WINX64.7z ...
Extraction: D:\ansys\ensight\WINX64.7z ...
Extraction: D:\ansys\configs\ensight\WINX64.7z ...
Extraction: D:\ansys\nexus\WINX64.7z ...
Extraction: D:\ansys\fensap\WINX64.7z ...
Extraction: D:\ansys\configs\fensap\WINX64.7z ...
Extraction: D:\ansys\configs\cfdpost\WINX64.7z ...
Extraction: D:\ansys\fluentc\WINX64.7z ...
Extraction: D:\ansys\fluents\WINX64.7z ...
Extraction: D:\ansys\fluenta\WINX64.7z ...
Extraction: D:\ansys\fluentu\WINX64.7z ...
Extraction: D:\ansys\fluentp\WINX64.7z ...
Extraction: D:\ansys\fluentm\WINX64.7z ...
Extraction: D:\ansys\fluent2d\WINX64.7z ...
Extraction: D:\ansys\fluent2ddp\WINX64.7z ...
Extraction: D:\ansys\fluent3d\WINX64.7z ...
Extraction: D:\ansys\fluent3ddp\WINX64.7z ...
Extraction: D:\ansys\addincfg\fluent\WINX64.7z ...
Extraction: D:\ansys\configs\fluent\WINX64.7z ...
Extraction: D:\ansys\distcomp\WINX64.7z ...
Extraction: D:\ansys\ensight_components\WINX64.7z ...
Extraction: D:\ansys\polyflow\WINX64.7z ...
Extraction: D:\ansys\addincfg\polyflow\WINX64.7z ...
Extraction: D:\ansys\addincfg\matpro\WINX64.7z ...
Extraction: D:\ansys\configs\polyflow\WINX64.7z ...
Extraction: D:\ansys\forte\WINX64.7z ...
Extraction: D:\ansys\addincfg\forte\WINX64.7z ...
Extraction: D:\ansys\configs\forte\WINX64.7z ...
Extraction: D:\ansys\turbogrd\WINX64.7z ...
Extraction: D:\ansys\configs\tg\WINX64.7z ...
Extraction: D:\ansys\aqwa\WINX64.7z ...
Extraction: D:\ansys\addincfg\aqwa\WINX64.7z ...
Extraction: D:\ansys\configs\aqwa\WINX64.7z ...
Extraction: D:\ansys\ansys\WINX64.7z ...
Extraction: D:\ansys\configs\ansys\WINX64.7z ...
Extraction: D:\ansys\addincfg\ansys\WINX64.7z ...
Extraction: D:\ansys\addincfg\matdes\WINX64.7z ...
Extraction: D:\ansys\solver\WINX64.7z ...
Extraction: D:\ansys\data\DATA.GZ ...
Extraction: D:\ansys\apdl\APDL.GZ ...
Extraction: D:\ansys\geompara\WINX64.7z ...
Extraction: D:\ansys\addincfg\mech\WINX64.7z ...
Extraction: D:\ansys\acp\WINX64.7z ...
Extraction: D:\ansys\addprintgeometry\WINX64.7z ...
Extraction: D:\ansys\addins\acp\WINX64.7z ...
Extraction: D:\ansys\configs\acp\WINX64.7z ...
Extraction: D:\ansys\shapeoptimization\WINX64.7z ...
Extraction: D:\ansys\dpf\plugins_composites\WINX64.7z ...
Extraction: D:\ansys\additive_cl\WINX64.7z ...
Extraction: D:\ansys\cads\acad\WINX64.7z ...
Extraction: D:\ansys\cads\cat5\WINX64.7z ...
Extraction: D:\ansys\cads\datakit\WINX64.7z ...
Extraction: D:\ansys\cads\osm\WINX64.7z ...
Extraction: D:\ansys\cads\fusion\WINX64.7z ...
Extraction: D:\ansys\geomproe\WINX64.7z ...
Extraction: D:\ansys\cads\pe\WINX64.7z ...
Extraction: D:\ansys\cads\ai\WINX64.7z ...
Extraction: D:\ansys\geomunig\WINX64.7z ...
Extraction: D:\ansys\cads\nx\WINX64.7z ...
Extraction: D:\ansys\cads\se\WINX64.7z ...
Extraction: D:\ansys\cads\sw\WINX64.7z ...
Extraction: D:\ansys\student\WINX64.7z ...
Extraction: D:\ansys\license\WINX64.7z ...
RSS is disabled
Creating Start Menu items for Ansys client licensing ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCommon.exe
Configuring Help ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigWB.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\Framework\bin\Win64\Ans.DriverSetup.exe
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\AnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2022 R2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Configuration 2022 R2.lnk
Creating Start Menu Shortcut for RSM 2022 R2 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Job Monitoring 2022 R2.lnk
Creating Start Menu Shortcut for RSM 2022 R2 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Cluster Monitoring 2022 R2.lnk
Creating Start Menu Shortcut for ARC 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\ARC Configuration 2022 R2.lnk
Creating Start Menu Shortcut for DCG 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\DCG Configuration 2022 R2.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCFX.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCHEMKIN.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigEnergico.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigRDWorkbench.exe
Configuring EnSight ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigEnsight.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFENSAP.exe
Configuring ANSYS CFD Post ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCFDPost.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFLUENT.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigPolyflow.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFORTE.exe
Configuring ANSYS TurboGrid ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigTG.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigAQWA.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Configuring ACP ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigACP.exe
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v222\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\Latest\CADConfigurationMgr.log
ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\CADConfigurationMgr.err
Prerequisites ..... Configure Success
SC Workbench PlugIn ..... Configure Success
Discovery Workbench Plugin ..... Not Configured
Successfully created file associations.
Installation Complete: Tue Nov 8 08:47:55 2022
workbench is starting but can't able to lanch Mechanical for modelling
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5364
3363
2471
1310
1018
