September 11, 2019 at 6:14 am
AndiMb93
SubscriberHi,
I'm trying to install Ansys 2019 R3 on OpenSUSE Leap 15.1. The installation is freezing at
AWPROOTDIR = /mnt/appl/x86_64/ansys_inc/v195
Creating ANSYS RSM Cluster Node Service script ...
Created service script: arcnode
There is nothing in the install.err.
Is there something I can do beside changing to another OS?
Andreas -
September 11, 2019 at 4:37 pm
tsiriaks
Ansys EmployeeDo you have libpng12 installed on the systems ? You can try checking Chapter 2 of ANSYS Install Guide for Linux. Make sure you systems have those prerequisites (or something similar/equivalent) installed.
Thanks,
Win
September 12, 2019 at 6:38 am
AndiMb93
SubscriberHi,
yes, libpng12 is installed. I tried to check the prerequisites and installed some additional 32bit libraries:
already installed:
libpng12-0, libpng12-0-32bit, motif, Mesa, libjpeg62, libXp6, xterm, libSM6, libstdc++-devel and C/C++ libraries
newly installed:
libSM6-32bit, libstdc++-devel-32bit, gtk2-tools-32bit, libXxf86vm1-32bit, libXt6-32bit, glib2-tools-32bit, libXp6-32bit
It still freezes at arcnode.
Andreas
September 12, 2019 at 11:24 pm
tsiriaks
Ansys EmployeeHi Andreas,
Can you check if lsb is installed ?
https://forums.opensuse.org/showthread.php/465474-openSUSE-11-4-does-not-install-LSB-by-default
Thanks,
Win
September 13, 2019 at 5:42 am
AndiMb93
SubscriberHi Win,
I checked and it wasn't installed, just lsb-release not the lsb core package. I installed but it still freezes at arcnode. Is there a way to check where and why the arcnode script is stopping working?
Andreas
September 13, 2019 at 7:42 pm
tsiriaks
There used to be a flag -debug that you can add when launching the installer but I've not used that for a long time, not sure if it still works with these new versions.
Could you try it ?
Thanks,
Win
September 18, 2019 at 8:31 am
AndiMb93
SubscriberHi Win,
I tried but I can't see anything in the debug informations. The installation process still stops at "Created service script: arcnode". The last line in the debug log is "Running configuration script"/mnt/appl/x86_64/ansys_inc/v195/commonfiles/configs/linx64/config/AnsConfigWB.sh" -installdir "/mnt/appl/x86_64/ansys_inc" -rev 195 -dotrev 2019 R3 -scripttosource "/mnt/appl/x86_64/ansys_inc/v195/commonfiles/configs/linx64/config/ConfigCommon.tcl" -sourcedir "/tmp/ans_install_tmp18294" -os_lang en-us -install -skip_file_associations"
Andreas
September 18, 2019 at 4:37 pm
tsiriaks
Ansys EmployeeAndreas,
what if you change the installation directory to be just the default one, like /ansys_inc/v195/
if this still doesn't work, I'm out of idea, sorry. You may have to use a supported OS.
Win
- Workbench error
- Workbench not opening
- License Error
2524
2064
1279
1096
456
