August 6, 2018 at 9:49 pm
banerian
Subscriberafter installing ver 18.2 on a new system (linux install) we proceeded with installation of 19.1
the "progress bar" got to 89% and then never terminated.
install.err.tmp is attached, except not, as this forum will not accept the file extension.
no indications as to how to proceed.
error log contents pasted below, as file upload seems to wedge this forum
###### Error #######
Error executing configuration script '/opt/ansys_inc/v191/commonfiles/configs/linx64/config/AnsConfigRSM.sh'
'"/opt/ansys_inc/v191/commonfiles/configs/linx64/config/AnsConfigRSM.sh" -installdir "/opt/ansys_inc" -rev 191 -dotrev 19.1 -scripttosource "/opt/ansys_inc/v191/commonfiles/configs/linx64/config/ConfigCommon.tcl" -sourcedir "/tmp/ans_install_tmp5750" -os_lang en-us -install -skip_file_associations ' terminated after 1 attempts with the following error(s):
Unknown error
Exit Code: 0
readlink: invalid option -- 'p'
Try 'readlink --help' for more information.
dirname: missing operand
Try 'dirname --help' for more information.
/opt/ansys_inc/v191/RSM/Config/tools/linux/rsmconfig: 26: /opt/ansys_inc/v191/RSM/Config/tools/linux/rsmconfig: /Framework/bin/Linux64/runwb2: not found/opt/ansys_inc/v191/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /opt/ansys_inc/v191/aisol/dll/linx64/libans.common.clrhostmonou.so: unexpected operator
/opt/ansys_inc/v191/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /opt/ansys_inc/v191/aisol/dll/linx64/libans.common.controlsu.so: unexpected operator
August 6, 2018 at 11:16 pm
David Yakinian
Ansys EmployeeHi,
What version of Linux are you running? Are you running it with root privilege? Make sure you are using a supported OS.
https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/ansys-platform-support-strategy-plans-april-2018.pdf?la=en
August 6, 2018 at 11:49 pm
banerian
Subscriberversion of Linux is a patched 4.9 kernel, a couple of custom modules for our hardware (chipset, graphics, etc)
18.2 ansys installed w/o problems reported, and the documents suggested installing newer version on top of older version, something about the licensing, IIRC.
18.2 launcher, fluent open.
is the 19.1 installer so different from 18.2?
August 7, 2018 at 5:15 pm
JakeC
Ansys EmployeeHi Banerian,
Which flavor of linux? Can you paste in the results of:
cat /etc/*release*
Additionally as David asked, are you installing as root?
Also which shell are you using? If not using bash, can you please switch to a bash shell and try that.
Lastly please make sure that you have the libpng12 library installed.
Thank you,
Jake
- The topic ‘Installation halts, gui hangs. ver 19.1’ is closed to new replies.
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8824
4658
3155
1688
1482
