Ansys Products
Ansys Products
Installation issue
    • Saos92
      I'm trying to install and run ANSYS 2020 R1 student version. But after all the installation is done the program is nowhere to be found in the computer.
      -I downloaded the program from the web site
      -extracted the files
      -run as admin the setup.exe file
      -Agree with the terms and conditions
      -selected the file to store
      -then search for it and nothing.
      Is there something wrong in my steps or can this be resolved by other means?
      If any other info is needed please let me know
      Thank You.
    • tsiriaks
      Open CMD Prompt, then type
      "%awp_root201%FrameworkbinWin64runwb2.exe"
      Does this launch Workbench successfully ?
      Do you have an install.err file under (default) C:Program FilesANSYS IncANSYS Student
    • Saos92
      Hello tsiriaks,
      The CMD step launched the program successfully. I got a license error  but when relaunching the the error is not showing
      The instal.err is not in the files.
      How can this be resolved?
    • tsiriaks
      So your installation is probably fine. It's just the issue with shortcut
      Browse to your ANSYS installation directory (default) C:Program FilesANSYS IncANSYS Studentv201
      then, right click on productconfig.exe and 'run as administrator'
      select Configure Products and make sure you select all products on the list and hit next.
      Does this make any difference with the shortcut ?
    • smmoaman
      Hi .. I have the same Problem.nI downloaded the last version of ansys v201 .. with the license from my university but I cant find the shortcuts .. unless i search them in the start menu.nIs there any way to have all the products in one folder ?.thanks in advancednn
    • peteroznewman
      nIn the Start Menu, you can find a product you want easy access to, such as Workbench. Right click on that and select Pin to Start. Then you will get a tile that makes it very easy to start Workbench. You can do the same for SpaceClaim or any other product.n
    • smmoaman
      Thank you n
Viewing 6 reply threads
