September 4, 2018 at 12:11 am
Globrother
SubscriberHello!
I've tried almost everything and I can not install the Ansys AIM student. The installation always ends with errors and this way I can not start the software.
- Already checked the username and it is ok;
- Already checked out the video drive and it looks like everything Ok (not automatic);
- Folder paths do not contain strange characters;
- I tried installing both Ansys AIM 19.1 and Ansys Workbench 19.1 (always the same error);
- I tried to install in C: and
(also with the same error);
The operating system is Windows 7 Professeonal
Video Card: NVIDIA GeForce 310M
the Error Log displays the following:
ANSYS installation: sáb set 1 02 : 36 : 13 2018
Revision: Release 19.1
###### Error #######
Error executing configuration script in 'C:UsersCleberAppDataLocalTempans_install_tmp5556configAnsConfigWB.tcl'
"C:UsersCleberAppDataLocalTempans_install_tmp5556tclbinwinx64tcl..." "C:UsersCleberAppDataLocalTempans_install_tmp5556configAnsConfigWB.tcl" -installdir "C:Program FilesANSYS IncANSYS Student" -rev 191 -dotrev 19.1 -scripttosource "C:UsersCleberAppDataLocalTempans_install_tmp5556configConfigCommon.tcl" -sourcedir "C:UsersCleberAppDataLocalTempans_install_tmp5556" -os_lang en-us -install ' terminated after 1 attempts with the following error(s):
Unknown error
Exit Code: 1
Graphics Driver Verification and Setup Error.
Below are some images of the program's startup error.
First error message when opening the software:
https://drive.google.com/open?id=15QFqBLYG_rilvdCFO_QAn7e-XhbfAs5K
And then :
https://drive.google.com/open?id=1mWu84_8eaxx3HySqNxIS8UiumRKx9Dh8
Thank you!
September 4, 2018 at 9:04 am
Ansys EmployeeHi,
Please can you check your hardware is supported https://www.ansys.com/Solutions/Solutions-by-Role/IT-Professionals/Platform-Support and that you're running the installer as Admin? They're the two most common issues so best to eliminate those first.
Best wishes,
September 4, 2018 at 4:12 pm
tsiriaks
Ansys EmployeeHi Globrother,
Aside from Rob's suggestions, also check if you have any pending Windows update and make sure you install them all. Then reinstall ANSYS again (make sure you remove ANSYS Inc folder before you attempt the new install)
If you still have an issue, please send the screenshot of the output of the command 'set' (without quote '') in the CMD Prompt.
Thank you,
Win
September 6, 2018 at 12:16 am
Globrother
SubscriberHi, thanks for the answers.
I did the suggested procedures, but without success.
I did the full Windows update, I uninstalled Ansys, I deleted the Ansys Inc folder, I reinstalled and the error remains the same.
Same problem with the AnsConfigWb.tcl file.
And I checked the https://www.ansys.com/Solutions/Solutions-by-Role/IT-Professionals/Platform-Support link and on the graphics cards page there is not the Gforce 310M from Nvidia which is my video card.
Thank you!
September 6, 2018 at 3:40 pm
tsiriaks
That's correct, we only support Quadro family , not GeForce. However, what you can try is to go to Nvidia website and check for the latest available driver for your model, then try to update your Nvidia GeForce driver to the latest version and reinstall ANSYS again.
If you could attach screenshot of the output of the command I mentioned that would help eliminate other causes of this issue as well.
Thank you,
Win
September 27, 2018 at 7:51 pm
Globrother
SubscriberHello!
I ended up installing version 19.0 of Ansys, but without success. Now I can not open geometry in the workbench.
The following error appears: " The Geometry editor was closed abnormally"
below is the output of the prompt for the set command:
I could not upgrade the video drive to the latest version of the dealer's site. So for one last try I will try to install version 18.2 of Ansys.
Grateful!
September 27, 2018 at 9:43 pm
tsiriaks
Thank you for the info. This helps eliminating the 'other' issue that I was thinking about.
For the 19.0 installation, do you see any error during the installation ? Or you only have this issue " The Geometry editor was closed abnormally" when launching the product ?
For the graphics driver, you meant you tried to run the installation but it didn't allow you to do so ?
Two other things to try aside from updating driver are
1. Manually register the DLLs listed below by starting a Command Prompt (DOS) "as administrator" and changing to the directory c:windowssystem32, then typing:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
2. Check the PATH System Variable to make sure that C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;… entries are in front of everything else.
Like: PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;…all other entries...
Thank you,
Win
September 28, 2018 at 2:00 am
Globrother
SubscriberHi tsiriaks,
I really could not update the video card drive, I tried several versions and to no avail.
The installation error continues even in version 19.0, the only difference is that I can now open the workbench. See the error below:
ANSYS installation: seg set 24 11:14:07 2018
Revision: Release 19.0
Error executing configuration script 'C:UsersCleberAppDataLocalTempans_install_tmp7360configAnsConfigWB.tcl'
'"C:UsersCleberAppDataLocalTempans_install_tmp7360...exe
"C:UsersCleberAppDataLocalTempans_install_tmp7360configAnsConfigWB.tcl" -installdir "E:Program FilesANSYS IncANSYS Student" -rev 190 -dotrev 19.0 -scripttosource "C:UsersCleberAppDataLocalTempans_install_tmp7360configConfigCommon.tcl" -sourcedir "C:UsersCleberAppDataLocalTempans_install_tmp7360" -os_lang en-us -install ' terminated after 1 attempts with the following error(s):
Unknown error
Exit Code: 1
Then I'll try those next steps.
thank you!
September 28, 2018 at 3:42 pm
tsiriaks
Have you tried this driver
https://www.nvidia.com/Download/driverResults.aspx/112598/en-us
This is the latest one available for your GeForce 310M with Windows 7. Unfortunately, it seems like they have stopped supporting this model, so even the latest one there , the driver is still very old (2016).
What is the exact error message when you are trying to install the driver ?
I would say, you can try my #2 first , along with updating the graphics driver and see if that makes any difference.
Note: For each attempt to reinstall the ANSYS Student version, make sure that you completely remove/delete the ANSYS Inc (or ANSYS Student) folder first.
Thank you,
Win
September 28, 2018 at 9:35 pm
Globrother
Subscriberthe NVIDIA installer says that no video card was found compatible with the drive, tested many versions and none worked, all presented the same problem.
procedure 1 above has been done and all the dlls are in c: windows system32.
Step 2 I did not fully understand what is to be done. you ask if the dlls are in those other directories too? No, the dlls are only in c: windows system32.
Then I opened the workbench 19.0, and now I can do some drawing in geometry, but after a while the message reappears "The Geometry editor was closed abnormally" but I close the message window and continue the work. usually it appears when you open the template
OBS: Would you have some material, manual, tutorial that would help with magnetostatic issues (permanent magnets)? If so, could you make it available? Thankful.
Thank you!
September 28, 2018 at 10:19 pm
tsiriaks
I forgot that your system might not be using English language as default. The driver link that I posted was for English (US).
I don't expect the software to fully/properly function because you have the issue during the installation and it can't configure the product successfully
You mentioned you are using Windows 7 Professional right ? If so, I don't think you can change default systems language to be English.
Did you also try the driver from here
https://www.nvidia.com/Download/index.aspx?lang=en-us
while filling out the following information
Product Type: GeForce
Product Series: GeForce 300M Seriese (Notebooks)
Operating Systems: Windows 7 64-bit
Language: language that your systems is using
If this doesn't work, now I think your GeForce card (hardware) might not be installed or working properly.
Go to CMD Prompt , then type 'dxdiag' (without quotation ' '), once it launches click 'Display' tab and capture the screenshot of it and post it here.
Let's hold off on the step #2 for now, don't move any dlls anywhere.
Thank you,
Win
September 30, 2018 at 2:40 am
Globrother
I filled it exactly like this:
Language: Portuguese (Brasil)
I tried again to install the video drive and still unsuccessfully.
Video Card Information:
Grateful!
October 1, 2018 at 4:06 pm
tsiriaks
Thank you for the screenshots.
So, the driver that you are using is in 2010. I'm not sure why you can't update to this 2016 driver. It may be best to consult with your IT or Nvidia support.
I would focus on getting this fix first, then you can try reinstalling ANSYS products again and see if you still get the error message.
Thank you,
Win
December 26, 2022 at 12:06 pm
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2508
2064
1279
1094
456
