October 21, 2018 at 5:23 pm
Eric Tsai
SubscriberHello,
This is the first time I installed the product ANSYS Student 19.2, and I have some problems make me crazy!
I follow the same step in this video, but I still can't find my Workbench to start my ANSYS. ===>
My laptop is using Win10:
1. I can't find the file of ANSYS and Workbench in the window start menu, so how should I open the product ?
2. I find there is a "install.err" file under C:Program FilesANSYS IncANSYS Student,
but the installer(where I click the setup button) said that it was install completed.
What's going on? I have no idea.... I spend almost 5 hours handling this problem, and I need to complete my homework next week, OMG !!
Somebody helps me, please!!!
October 22, 2018 at 2:33 am
SubscriberClick the Search icon next to the Windows button in the lower left.
Type Workbench
What does it find?
It should find Workbench 19.2
Desktop app
October 22, 2018 at 6:54 am
Keyur Kanade
Ansys EmployeeHi,
Please use 'Run as administrator' while installing. Please make sure that you have read/write permissions.
Also please go to C:Program FilesANSYS Incv192FrameworkbinWin64 anduse RunWB2.exe to open workbench.
If you can not find RunWB2 then your installation is not complete and you may need to reinstall it correctly.
Keyur
October 22, 2018 at 6:55 am
Keyur Kanade
Ansys EmployeeAlso as its installation related, I am moving this to Installation category for better response.
Keyur
October 22, 2018 at 1:19 pm
JakeC
Ansys EmployeeIf for some reason windows 10 is not updating the start menu, you can run workbench by running the following:
C:Program FilesANSYS IncANSYS StudentFrameworkbinwinx64Runwb2.exe
Thank you,
Jake
October 23, 2018 at 4:10 am
Keyur Kanade
Ansys EmployeeHi,
Did it help you? Are you able to run it using Runwb2.exe?
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
Keyur
January 21, 2021 at 1:56 pm
January 25, 2021 at 2:42 pm
George Karnos
Ansys EmployeeOpen a Windows file explorer window and type the following in the Address line:n%APPDATA%\AnsysnYou should see a directory under the above directory named: v###, that is associated with your installed version.nrename this directory to V###.oldnTry to run again.n
- Workbench error
- Workbench not opening
- License Error
2524
2066
1279
1096
459
