January 13, 2020 at 11:33 am
viochnova
SubscriberHello,
I have a problem with installation of Discovery 2020R1. At the end, there is always message, that installation was completed with error and I should to check files with .err or .log and the programs (Live, AIM, SpaceClaim 2020) are not installed.
I attach the file, because I can not recognize, where is the problem. So could you help me with it?
Thank you in advanced
Natalie
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
January 13, 2020 at 12:17 pm
Subashni Ravichandran
Ansys EmployeeHello Natalie
Could you please confirm that you have launched the installers with Administrator rights?
Could you also check with your IT team if you have permissions to write to the Windows Registry?If that does not work, could you please go through #6 of the Troubleshooting Document and also send us the Install.log and Install_licconfig.log?
January 14, 2020 at 9:01 am
Thank you for sharing the files via email.
Could you please check with your IT team and confirm if you have implemented the #5A in the Troubleshooting Document?Also, if you have a proxy server in place, can you please check #5B as well?
If you still have an issue after following the above suggestions please let us know.
January 14, 2020 at 9:25 am
viochnova
SubscriberHello Subashni ,
thank you for the quick response.
I swich off firewall and swich off firewall of antivirus, I set exception for ansysls_client.exe everywhere it was possible in antivirus, but the problem still persists. :(
Natalie
January 14, 2020 at 9:26 am
viochnova
Subscriber... we do not use proxy server
January 14, 2020 at 11:27 am
I discussed your issue with my team and I received the following suggestion.
Could you please uninstall the application, delete the installation directory and extract the downloaded installer and then re-install the application with Admin rights?
If this does not work we could arrange a Webex see what could be causing the issue.
January 14, 2020 at 12:25 pm
viochnova
It is finally works. Thank you for your help.
Natalie
3820
2607
1853
1244
600
