Ansys Products
Ansys Products
Installed license to a new server and I see license failure message when I install.
    • mgjeong
    • ANSYS_MMadore
      Please share the full error message. The message is cutoff, you can either expand the window or scroll down and take another screenshot.
    • mgjeong
      Failover feature 'Ansys electronics_desktop' is not available.
      Request name electronics_desktop does not exist in the licensing pool.
      Cannot connect to license server system.
      The license server manager (lmgrd) has not been started yet the wrong port@host or license file is being used, or the
      port or hostname in the license file has been changed.
      Feature
      electronics_desktop
      Server name
      129.10.132.63
      License path
      1055@129.10.132.63;
      FlexNet Licensing error
      -15,10032
      but the license server is working.
    • ANSYS_MMadore
      Please run these commands on your local machine and share the full output.
      ping 129.10.132.63
      ipconfig /all
    • mgjeong
      C:\Users\mingy>ping 129.10.132.63
      Pinging 129.10.132.63 with 32 bytes of data:
      Request timed out.
      Request timed out.
      Request timed out.
      Request timed out.
      Ping statistics for 129.10.132.63:
      Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
      C:\Users\mingy>ipconfig /all
      Windows IP Configuration
      Host Name . . . . . . . . . . . . : MGWorkstation
      Primary Dns Suffix. . . . . . . :
      Node Type . . . . . . . . . . . . : Hybrid
      IP Routing Enabled. . . . . . . . : No
      WINS Proxy Enabled. . . . . . . . : No
      DNS Suffix Search List. . . . . . : nunet.neu.edu
      Ethernet adapter Ethernet:
      Media State . . . . . . . . . . . : Media disconnected
      Connection-specific DNS Suffix. :
      Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
      Physical Address. . . . . . . . . : F0-2F-74-1D-F4-CE
      DHCP Enabled. . . . . . . . . . . : Yes
      Autoconfiguration Enabled . . . . : Yes
      Ethernet adapter Ethernet 2:
      Connection-specific DNS Suffix. : nunet.neu.edu
      Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
      Physical Address. . . . . . . . . : F0-2F-74-1D-F4-CD
      Link-local IPv6 Address . . . . . : fe80::dc6e:9f97:f705:8158%13(Preferred)
      IPv4 Address. . . . . . . . . . . : 129.10.135.203(Preferred)
      Subnet Mask . . . . . . . . . . . : 255.255.252.0
      Lease Obtained. . . . . . . . . . : Wednesday, August 25, 2021 8:24:56 PM
      Lease Expires . . . . . . . . . . : Saturday, August 28, 2021 2:24:53 AM
      Default Gateway . . . . . . . . . : 129.10.132.11
      DHCP Server . . . . . . . . . . . : 155.33.2.129
      DHCPv6 IAID . . . . . . . . . . . : 284176244
      DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-B7-5C-96-F0-2F-74-1D-F4-CE
      DNS Servers . . . . . . . . . . . : 155.33.2.1
      155.33.2.2
      NetBIOS over Tcpip. . . . . . . . : Enabled
      Wireless LAN adapter Wi-Fi:
      Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX200 160MHz
      Physical Address. . . . . . . . . : DC-41-A9-BA-00-09
      Wireless LAN adapter Local Area Connection* 1:
      Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
      Physical Address. . . . . . . . . : DC-41-A9-BA-00-0A
      Wireless LAN adapter Local Area Connection* 2:
      Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
      Physical Address. . . . . . . . . : DE-41-A9-BA-00-09
      Ethernet adapter Bluetooth Network Connection:
      Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
      Physical Address. . . . . . . . . : DC-41-A9-BA-00-0D
    • ANSYS_MMadore
      This shows you can't ping the server, which will prevent license access. Perhaps PING is disabled, can you open Windows Powershell and run this command and send the output?
      Test-NetConnection 129.10.132.63 -Port 1055
    • mgjeong
      PS C:\Users\mingy> Test-NetConnection 129.10.132.63 -Port 1055WARNING: TCP connect to (129.10.132.63 : 1055) failedWARNING: Ping to 129.10.132.63 failed with status: TimedOut
      ComputerName: 129.10.132.63
      RemoteAddress: 129.10.132.63
      RemotePort: 1055
      InterfaceAlias: Ethernet 2
      SourceAddress: 129.10.135.203
      PingSucceeded: False
      PingReplyDetails (RTT) : 0 ms
      TcpTestSucceeded: False
      It seems that the connection is prevented by something.
      How could I fix this issue?
    • ANSYS_MMadore
      This is something you would need to work with IT to resolve. There are likely firewalls in the way, or other network restriction preventing access.
    • mgjeong
      I got this from the IT team.
      I reviewed the steps that were taken with Ansys. Since both devices are on the same network, there is no firewall in between. Most likely, there is a local firewall on your new ansys server that needs to be modified to allow the trafic.
    • ANSYS_MMadore
      Please see this video for adding firewall exceptions on the license server machine.
      http://storage.ansys.com/doclinks/videos.html?code=ConfigFirewallExc-VLU-M2a
    • mgjeong
      Now it work! thank you very much!!
    • mgjeong
      I am trying to access the license server we set.
      However, when I start Ansys Electronics Desktop, it shows this error message.
      Feature
      electronics_desktop
      Server name
      129.10.135.63
      License path
      1055@129.10.135.63;
      -15,10032
      I also did the ping test.
      RemotePort: 1055
      TcpTestSucceeded : True
      I also did
      things shown in the webpage.
      Could you let me know how to solve this problem?
    • ANSYS_MMadore
      Please make sure the port for the ansyslmd daemon is open on the license server firewall. You can set ansyslmd to a static port by adding it in the license file on the VENDOR line.
      For example:
      VENDOR ansyslmd PORT=1056
Viewing 12 reply threads
