December 8, 2022 at 12:51 pm
Louis Wald
SubscriberApologies for adding this post multiple times.
I am an Ansys beginner and would appreciate some help. I'm getting an 'Insufficient HPC licenses available' error when attempting to solve a very simple Magnetostatic problem. I'm continuing to solve (small)) Static Structural, Steady-State thermal and Modal without a problem.
Note that I have not set GPU processing on (as suggested might be the problem on this forum)
Any help would be much appreciated. -
December 8, 2022 at 5:21 pm
George Karnos
Ansys EmployeeAre you using the same number of cores for Magnetostatic as you are for the Static Structural
and Steady-State Thermal jobs?
If you go to:
%TEMP%\.ansys
You should see .out files
These are licensing debug files for the jobs.
Can you check the .out files for the error and post it here? -
December 9, 2022 at 1:15 am
Louis Wald
SubscriberI found out how to change cores to 2 in the Solve area. Everything works now. Yay
Thanks
January 5, 2023 at 7:21 am
ZMIRLI kalidod
SubscriberGreetings, I utilize conversant in HPC of my universty. I can utilize 16 centers yet when I attempt 62 or 32 now and again it works yet here and there doesn’t. I get the followong blunder. ANSYS Permit Supervisor ERROR:Not enough Familiar – HPC licenses 64/16. To the extent that I realize the permit is scholastic examination permit. How might I realize what is utilized permit and what is its center cutoff points ?
- Maxwell, HFSS or Q3D?
- Error
2564
2080
1299
1106
459
