August 21, 2023 at 7:21 am
Aruna_Soibam
SubscriberHello,
In my system, the drive has 268 GB free; however, when I try to visualize the E-field from a frequency domain power monitor (2D Z-normal) for a Lumerical FDTD file with 22.9 GB size (after running the simulation), it is showing "The program must be terminated due to insufficient memory".
What can be the solution for this? Kindly help.
Thanks,
Aruna
August 22, 2023 at 9:40 pm
Guilin Sun
Ansys EmployeeIt is difficult to help since the informaiton is limited . 268 GB is the hard disk or memory? it needs large memory to display the data. It might also be related to display card memory.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7686
4476
2957
1435
1322
