May 11, 2023 at 11:21 am
Peter Felbinger
SubscriberHello folks,
i have a problem for the integration of surface tension and contact angle in my simulation.
I have a small cylinder that rotates around a axis with 900rpm. The fluid is simulated with a Level Set-VOF. I have two different fluids A and B.
A has a surface tension of 0.072 N/m and a contact angle with the wall of 102.1°
B has a surface tension of 0.049 N/m and a contact angle with the wall of 57°
These values are put in the phase interaction tab and in the wall boundary tab
When i run the two simulations and plot the phase fraction of water, the results look identical (left is fluid A, right is fluid B).
Do i miss something that i have to define?
May 11, 2023 at 12:44 pm
Ansys EmployeeIt looks like you set wall adhesion, otherwise you'd not see the free surface distortion. How well refined is the mesh?
May 11, 2023 at 1:53 pm
May 11, 2023 at 2:25 pm
Ansys EmployeeOK, you're looking at cell quality. Mesh quality also includes resolution. So, how many cells are there near the walls? Convergence?
May 12, 2023 at 5:36 am
May 12, 2023 at 9:15 am
Ansys EmployeeSo, how many cells in the region next to the wall? Please post a volume fraction contour with node values off.
That's not overly well converged, so I'd be very wary of drawing too many conclusions from the model.
May 12, 2023 at 9:32 am
May 12, 2023 at 10:01 am
Ansys EmployeeAnd after it's run? Turn node values OFF.
May 12, 2023 at 11:42 am
May 12, 2023 at 12:10 pm
Ansys EmployeeWhat's the contact angle on the bottom?
May 12, 2023 at 12:32 pm
Peter Felbinger
SubscriberThat should be 102.1° as i specified in the BC
May 12, 2023 at 1:06 pm
Ansys EmployeeNot sure, does mesh refinement help?
5028
3137
2373
1306
922
