October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYes. You can use the MAPDL commands SECTYPE and SECDATA to change the number of integration points though the thickness in a shell. For example, the following commands could be issued in a Command Object under a “Surface” branch in Mechanical: !----INPUT PARAMETERS----! Thick=2 ! Shell Thickness Theta=0 ! Angle (in degrees) of layer element coordinate system with respect to element coordinate system (ESYS) IntPoints=3! Number of integration points in layer. 1, 3, 5, 7, or 9 points (default = 3) !
END INPUT
! SECTYPE,matid,shell SECDATA, Thick,,Theta,IntPoints -
October 4, 2017 at 2:39 pm
pgl
Ansys EmployeeIs it possible to change the number of integration points in a shell element?
2120
1345
1118
461
