TAGGED: bend, designmodulator, interconnect, ring-resonators
February 10, 2022 at 1:33 am
Stefan_1029
SubscriberPlease find attached a screenshot of the error I'm getting when simulating a ring resonator using imported mode profiles from MODE. It looks like it cannot load one of the profiles (a bend in this case) and I'm not sure how to proceed. I've tried exporting it a lot of times and it keeps giving the same error. It's very specific to the bent mode profile I'm importing as it's working perfectly with everything else.
February 10, 2022 at 7:05 pmGuanhui Wang
Ansys EmployeeHi Stefan_1029
This looks to be a problem in the file. I cannot see the last picture you attached and unfortunately we cannot open any files attached in this forum due to ITAR restrictions. Could you pelase attach the screenshot for the data int he file? If the file is valid defined, a bold guess based on the error message is that the file is so long so when import it to INTC it got cut off in the middile so INTC recognize it as an unexpected end. In this case please try to remove some part of the file but keep the same format of it, and try to reoload it into INTC to see whether this can help to resolve the issue.
- Error on Lumerical device
3930
2649
1861
1272
610
