July 26, 2023 at 7:34 pm
August 4, 2023 at 10:57 pm
Devika Padmakumar Nair
Ansys EmployeeHello, Can you elaborate a little more, for example which lumerical example you are using for a reference? Which elements are using in interconnect.
It is important for you to copy and paste some important information, and simulation settings as well as results in question. Description should be in detail. The more details you can provid the faster you get a suggested solution.
Thank you
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7804
4508
2979
1449
1322
