Interface Selection
    • lancer
      Hi, I'm currently doing research involving heat and reaction occuring from Fluid to Fluid Interface and Fluid to Solid Interface. I used Boolean in the Design Modeler, and in Setup I used the mesh interface feature to connect the two interface. But, when I want to select the interface, there is  a lot of similar as per below:
      My question is if I want to select the intf:08 or other, do I select all three of them such as intf:08-interior-1-1, interface_chccc-non-overlapping and interface_ccchc-non-overlapping. OR do I just select one of them?
      or is this the wrong way to make interface?
      The easiest approach is to create a multibody part in DM as that'll give you a conformal mesh and you don't then need the interface zones. However, that looks like Fluent has automatically set up some/all of the zones so you may not need to do anything.
      • lancer
        Any youtube channel or reference I can refer?
      Have a look in "Help" for tutorials and videos. Multibody parts are covered in DM, interfaces in Fluent.
      • lancer
        To tell you the truth, I have no idea like multibody part, conformal mesh. So I don't know what to click help or what tutorial to learn.
      Do all of them. The tutorials are intended to get you some way up the learning curve, YouTube gets you a bit further.
Viewing 3 reply threads
