Ansys Products
Ansys Products
Interface wall thermal BC parameters for battery module
    • lilly santana
      I am trying to simulate the mid-plane of a lithium ion battery module in ANSYS Fluent (see attached image for idea of geometry) - so it's a 2D simulation. The circles represent solid battery cells and the rest is fluid flowing around the cells. I want to tell Fluent that the cells generate 2W of heat but I'm a bit confused on what to type in for the interface wall thermal BC inputs at the boundaries of the cells (see second attached image). I calculated the heat flux using 2/(2*pi*r*L) and made the thickness zero. Was the calculation of heat flux correct despite it being a 2D simulation? also, I am unsure on what I should put for the heat generation rate? Thank you!!
    • Nikhil Narale
      You can't assume it 0. You must have assumed it 1, which is in a way correct, considering that other dimensions are also in meters.
      For a 2D case, Fluent uses 1 m as a default depth. You can change the depth value from the 'Reference Values' section.
      Nikhil
    • lilly santana
      Thank you for your reply. Can't assume what is zero?
    • Nikhil Narale
      "made the thickness zero"
      Solver will by default use 1 m as the depth(thickness).
    • lilly santana
      Hi Nikhil,
      Is this why Fluent makes my mesh 3D even though my simulation is 2D? mesh appears to be 1 cell thick?
    • Nikhil Narale
      Are you using Fluent's post-processing or CFD-post?
    • lilly santana
      it does this in the meshing stage not post processing
Viewing 6 reply threads
