3D Design
3D Design
Interfaces between Solid and Liquid surfaces
    • lancer
      Hello after using for a while, and wanted to know if I should use Boolean's interface or just by Form new part.
      Below is my model, so if I use Boolean I will use the Imprint. If new part, I don't have the interface name selection.
      The main purpose for the solid to fluid interface is to transport electron from the solid to the fluid.
      Anyone has advice on this matter?
    • Keyur Kanade
      Please check share topology option.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/spaceclaim/Discovery/user_manual/st_sharetopology.html?q=share%20topology
      Keyur
