August 26, 2019 at 11:25 am
krndv
SubscriberHello
I have modelled a bubble column reactor with discrete population balance model . Can anyone help me calculate interfactial area od secondary phase or atleast sauter mean diameter?
Thank you
Krndv -
August 28, 2019 at 12:10 pm
Ansys EmployeePBM is rather complex, and we're limited to what's in the documentation in many cases. I assume you've read the doc? From memory you need to divide one of the moments by one of the other moments to get D32 and interface area is directly taken from a moment.
September 2, 2019 at 3:19 pm
krndv
SubscriberThe diameter mentioned in " countours > Parameter > Diameter" is the D32 right?
Model: Eulerian Multiphase (water and air) with PBM
September 3, 2019 at 9:00 am
Ansys EmployeeNot sure, PBM is on my list to learn properly, for now please read the manuals!
October 16, 2019 at 8:27 am
krndv
Any specific answer for this?
Also in user manual its given, moments can be found for discrete model from population balance variables. But I am unable to find 'moments' as a variable in discrete PBM model post processing.
If I can get moments, m3/m2 will give D32 right?
Using Fluent 19.
December 18, 2019 at 11:15 am
krndv
SubscriberCase: Multiphase water-air system with population balance model.
Can anyone give a proper answer for above doubt?
Regards
Kdev
December 18, 2019 at 12:19 pm
DrAmine
Ansys EmployeeSauter Mean is under Properties>Diameter. Interfacial Area is just using that sauter mean and the total volume fraction
2630
2104
1327
1110
461
