Interference fit
    • javat33489
      I'm trying to do an interference fit with no ekill. Using the contact add offset ramped effects.
      I have a cylinder which consists of hundreds of plates. The ends of the plate enter into each other.
      I use contact add offset ramped effects and dedicate a whole step in the solution for this. Why is there no interference landing?
    • Ashish Khemka
      Can you try sharing other applied boundary conditions? Try using a large number of substeps. Also, you can turn off small sliding in the above contact settings.
      Ashish Khemka
