3D Design
3D Design
Interference fit cylinders mesh error
    • hassam
      I am trying to model an axisymmetric 2D model of interference fit for pressure cylinders. When trying to create mesh one of the surfaces seems to be obsolete or green in color. I cant really figure out the solution to this problem. Is there something wrong with the geometry because of freeze command or its not properly attached to the entire model?
    • peteroznewman
      If you click on the Vertex geometry filter, does the mesh show properly?
    • hassam
      Hello
      I could not find the Vertex geometry filter but when i closed the mechanical analysis windows  and reopened it  it the mesh is showing on both surfaces .
