October 23, 2018 at 11:57 pm
sanusi
SubscriberInternal combustion engines either spark ignition or compression ignition have peculiarities for simulation. basically, it comprises the following steps.
geometry importing and decomposition
mesh generation
problem set up
solution and result, like the regular ansys simulation but each cell operation in ICE is a different ball game.
October 24, 2018 at 12:01 am
sanusi
SubscriberI'm still trying to figure out the best ANSYS version for ICE simulation. also whether ICE forte is better than ICE fluent
October 31, 2018 at 4:45 pm
Ansys EmployeeCurrently it depends on what you're trying to model, and in how much detail. There's currently more Fluent expertise in the community which may be a factor if you need help.
January 10, 2019 at 2:37 pm
sanusi
SubscriberI'm modelling a CI engine combustion using different fuels blends of diesel and biodiesel. i want to study the combustion and emission properties of both the fuel blends as well as the engine.
January 11, 2019 at 12:03 pm
Ansys EmployeeProbably Forte then: unfortunately we're reliant on the community for help with that solver.
January 26, 2020 at 10:29 pm
AbdulkadirYalcinkaya
SubscriberHi Sanusi,
Can you tell us about how you mix diesel and biodiesel?
2524
2066
1279
1096
457
