Discovery Import
Discovery Import
INTERNAL FLOW – SHOW TRANSPARENT SOLID
    • wayne.remnant
      I can not find a way to show the transparent model when running an internal flow simulation.  I have been able to do this in the past, but now I seem to only be able to see the flow simulation and a wireframe model.  How do I show the flow and a transparent solid model?
    • Devendra Badgujar
      Hello Greyroad
      I'm looking into this. I'll get back to you.
      Regards.
    • Devendra Badgujar
      Hello Greyroad Please can you try unhiding the solids and check. I have attached the snapshot to unhide/Show the solids option from structure tree. Regards.
