August 29, 2018 at 9:38 pm
danielc358
SubscriberAfter the reverse engineering of the part, is the volume and the structure of a hollow surface?
August 29, 2018 at 9:57 pm
SubscriberWhat do you mean "reverse engineering" of the part?
You need to explain what have at the beginning, what you did to it, and what you are trying to accomplish.
August 29, 2018 at 10:08 pm
danielc358
SubscriberI extracted the outline of my piece with other software, but the piece is hollow and the software created two solids, my question is if one of these solids is the volume and the other the part's structure?, I re-partition the surface of the ask to use it on ansys.
August 29, 2018 at 10:35 pm
Sandeep Medikonda
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
