March 13, 2021 at 1:12 am
Guanhui Wang
Ansys EmployeeThe spatial data available from a DEVICE simulation such as charge, electric field, or temperature profile are all saved on a finite element grid. These data can be easily visualized from the visualizer but not easy to manipulate, i.e., adding/subtracting different data or getting partial data on a plane or along a line. It is therefore often desirable to interpolate these finite element data onto a rectilinear grid for post processing. The interpolated data can also be exported to other software such as Matlab for further processing.
The two script commands that can be used to perform this interpolation is interptri 59 (2D) and interptet 21 (3D). The KB page for interptri 59 has a detailed example on how to interpolate 2D finite element data onto a rectilinear grid. Similar approach can be used to interpolate 3D finite element data using the interptet command.
The following is an example of a combination of script commands that can be used to interpolate 3D charge data onto a rectilinear grid and then plot the data along a line.
[code]# get charge data
charge = getresult(‘CHARGE’,‘charge’);
n = pinch(charge.n);
p = pinch(charge.p);
get information about the finite elemetn data
x = charge.x; # x coordinates
y = charge.y; # y coordinates
z = charge.z; # z coordinates
vtx = [x,y,z];
elements = charge.elements; # connectivity matrix
kern = size(n);
Ne = kern(1); # Number of elements
Nv = kern(2); # Number of bias points
Define rectilinear grid
delta = 1e-9;
x_rect = linspace(min(x),max(x),5);
y_rect = linspace(min(y),max(y),5);
z_rect = linspace(min(z),max(z),101);
pick one bias point (last one)
n = n(1:Ne,Nv);
p = p(1:Ne,Nv);
Interpolate
n_rect = interptet(elements,vtx,n,x_rect,y_rect,z_rect); # interpolating n
p_rect = interptet(elements,vtx,p,x_rect,y_rect,z_rect); # interpolating p
plot n and p along Z
plot(z_rect(11:91)*1e6,n_rect(3,3,11:91),p_rect(3,3,11:91),‘z (um)’,‘carrier density (/cm^3)’,’’,‘log10y’);
legend(‘n’,‘p’);[/code]
The script generates the following plot:
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2600
2088
1317
1108
459
