Tagged: backflow, mass-fraction, mole-fraction, pressure-outlet, species
March 17, 2022 at 8:25 pm
julia.hartig
SubscriberHey all,
I'm running a transient simulation where backflow occurs periodically through the outlet (a "pressure outflow" BC) due to domain vibration. Since the species fractions near the outlet are time-dependent, there is no appropriate constant mole fraction to set for backflow - at the start of the simulation (i.e t=0s), the backflow condition is most appropriately described by ambient conditions (i.e. n2~0.78, o2~0.22) but as the simulation progresses and product gases reach the outlet, we would expect a more complex stream also containing our byproducts (methane, etc.). I've noticed this is introducing oscillations at the outlet and other unphysical behavior.
I would like to have Fluent assign backflow species concentrations based on the nearest neighboring cell or collection of cells (i.e. closest "downstream" cell) which I should be able to do with a UDF, but I only see options for a constant, parameter-based or expression-based assignment in the species dialog box of the pressure BC. It seems like maybe this would be possible with an expression, since this has a "Locations" dropdown containing my outlet (i.e. 'outlet-top') but I don't know how to reference specific properties/simulation values at this location.
Any advice on how to tackle this issue would be greatly appreciated! I'm leafing through the Users Guide but not seeing any examples relevant to what I'm trying to do so far.
March 18, 2022 at 11:20 amRob
Ansys EmployeeExpressions ought to do it, but you may need to use the average value from the near boundary region. The facet value on the boundary should include the boundary setting in the calculation so may not be what you want.
March 18, 2022 at 8:11 pmjulia.hartig
SubscriberRob Okay that makes sense. I'm really close... but I can't figure out how to make a near-outlet region that will actually appear in the "Locations -> Boundary Zones/Surfaces" dropdown. I created a surface, "outlet_line", but it's not recognized by the expressions utility. If I override it (hardcode the location to "outlet_line") it says that region is invalid.
I guess one way to do this would be to split the outlet tube into two pieces, mesh the interface, and then use that interface as the species averaging location? I hate to do this because it requires reimporting the mesh and redoing the case, and won't be very flexible if I find a better location to extrapolate species fractions from, but maybe this is the only option? What do you think?
March 21, 2022 at 11:52 amRob
Ansys EmployeeYou need to split the mesh to get a "proper" surface, but try with a plane too as some of the tools work on those but not iso-surfaces. If the mesh is fairly well aligned near the outlet you can use a register to split the mesh in Fluent. No need to re-mesh.
March 21, 2022 at 4:37 pmjulia.hartig
SubscriberI didn't realize you could split the mesh inside Fluent directly, your suggestion is a much easier approach :) Unfortunately the "Surfaces -> New -> Plane" option is greyed out since I'm working in 2D, so I tried splitting with a register. So far it's running without issues, I'll have to see how the results look when it finishes.
March 21, 2022 at 6:43 pmDrAmine
Ansys EmployeeUsing udf and providing the t0 value on the face profile.
March 22, 2022 at 5:49 pmjulia.hartig
SubscriberThe simulation just finished and the backflow results look good so I think this worked. Thanks for the help Rob! :)
Viewing 6 reply threads- You must be logged in to reply to this topic.
2518
2064
1279
1094
456
