Interpolation in Fluent batch mode
    • Thodorisdm
      I am trying to read interpolation data for my case which I am running on HPC in batch mode but I get this error . I have tried to upload the .dat file again but I always get the below error. On the other hand, when I am reading the same .ip file for the same .cas and .dat file in my computer I do not get any error.
      EDIT: I found what the problem was: I used WINSCP to transfer the .ip files to the HPC server which changed the encoding to UTF-8 and thus I got the below error. However, I uploaded the files with Filezilla and work perfect but I would like to know if there is another way to fix this error as I had written a script to transfer the files automatically and now I have to do it manually.
      Reading IP data ...
      x-coord
      y-coord
      z-coord
      pressure
      x-velocity
      y-velocity
      z-velocity
      k
      omega
      hyb_init-0
      hyb_init-1
      mp-1
      mp-2
       Done.
       Initializing values...
      error:nearest value not found
      Fatal error has happened to some of the processes!
      Exiting ...
      Forum Moderator
      Can you initialise the model on HPC and then read the IP file? If you're reading data why do you need the interpolation step?
    • Thodorisdm
      I mentioned the. dat files due to hurry. The reason is because I uploaded the files with WINSCP (check my EDIT paragraph) and the encoding of the .ip files changed to UTF-8. However, now I am using Filezilla but I cannot automate it as I could with WINSCP . Therefore, do you know another workaround so that I can still upload the .ip files to the server with WinSCP?
      Thank you in advance!
      Forum Moderator
      I've never noticed anything, we use WinSCP to transfer from local machines to the clusters. Maybe the Transfer Setting?
    • DrAmine
      Please ­ƒÖÅ contact WinScp.
Viewing 4 reply threads
