June 17, 2020 at 8:05 pm
RVVarun
SubscriberPROBLEM: Interpolation of points, which are later differentiated to study the curvature
USED COMMANDS/METHODS: I've tried using MFOURI, VITRP, and MOPER commands which generate interpreted data, however, the generated points when differentiated and plotted yield wavy/noisy behaviour (not desired) as the blue curve in the picture. This is because these commands apply different techniques of interpolation.
QUESTION: Are there any commands which use piecewise cubic interpolation with the not-a-knot method?
Any suggestions are heartily appreciated, thanks in advance!
Regards
RVVarun
June 18, 2020 at 12:37 am
Karthik R
AdministratorHello,
Could you please confirm if you are using Mechanical APDL here?
Thanks.
Karthik
June 18, 2020 at 7:28 am
RVVarun
SubscriberHello Mr Karthik,
yes, I am using ANSYS APDL for interpolation. The points were later plotted in MS-Excel.
Thanks,
RVVarun
October 6, 2020 at 9:19 am
RVVarun
SubscriberHi all,ni have implemented De-Boor algorithm for my Problem and it worked for me. Consider this discussion is closed.nregards,nRVVarunn -
October 6, 2020 at 11:35 pm
tsiriaks
Ansys EmployeeThank you for the input RVVarunn
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3812
2607
1853
1244
600
