Platform
Platform
Intersection error when importing model from SpaceClaim into Maxwell
    • Jón Andri Árnason
      Hello, I am having a problem with transferring my model from SpaceClaim into Maxwell, it's a somewhat simple model of three-volume conductors in contact with each other. When I test the model for errors in SpaceClaim I get no errors, even when I run an intersection check, I get no messages. However, when I import the data into Maxwell I get an intersection error as seen in the following image. I am using Workbench to link the programs.
      I have tried to fix the issue in Maxwell using the auto-fix feature but that seems to break it even more.
      Thank you for any help.
    • GLUO
      Could you try using draw>>subtract to remove one of the intersected parts?
      GL
