May 18, 2022 at 8:48 am
GeorgM
SubscriberWhen I choose "skip intersection checks" in the design settings, and I have intersections between different dielectrics, which one wins in the intersection region?
Thanks
Georg
May 20, 2022 at 9:38 amGeorgM
SubscriberFinally I have found the rule. It is simple: The smaller object wins over the larger one, no matter of the size of the intersection region.
May 20, 2022 at 12:42 pmPraneeth
Thanks for reaching to us and sharing your thoughts.
Please note that this is true only when the small object is fully surrounded by the larger object in all directions.
If not then it is treated as error and the model has to be rectified.
All the very best Praneeth.
May 20, 2022 at 12:58 pmGeorgM
SubscriberHi Praneeth thanks for your answer. The statement with the surrounding object is a documented feature. In the original post I addressed the case where "skip intersection checks" is active. In this case you will not get an error message, even if there is no full enclosure. Then the smaller object wins over the larger one, no matter of the size or shape of the intersection region. According to my experiments, small and large is a matter of volume, not shape.
Cheers
Georg
Viewing 3 reply threads- The topic ‘Intersections in HFSS’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
