Ansys Products
Ansys Products
Invalid argument passed to bulk checkout
    • Jocelyn Dubuc
      I just installed Ansys student 2021R2 and I'm unable to use SpaceClaim. I can open a project in Workbench just fine but when I try to open SpaceClaim (either through the project or just standalone) I get this error message, followed by a message telling me that no valid license was found. However, the license should be built-in and valid until 01/31/2023. How can I get SpaceClaim to work?
    • George Karnos
      Under %TEMP%\.ansys you should see license debug files.
      Are there any errors listed in the debug files?
      • Jocelyn Dubuc
        Here is what I see in the license debug file when I try to open SpaceClaim. Please let me know if this isn't what you're talking about.
        • Jocelyn Dubuc
          When I open licdebug.SPACECLAIM.212.out, this is what I see for my most recent start-up of SpaceClaim:
          2022/10/19 15:16:28    INFO                Starting Licensing Client Proxy server.
          2022/10/19 15:16:28    INFO                C:\Program Files\ANSYS Inc\ANSYS Student\v212\licensingclient\winx64\ansyscl.exe -acl 7228.63445 -nodaemon -log C:\Users\jocel\AppData\Local\Temp\.ansys\ansyscl.BonneJournée.7228.63445.log
          2022/10/19 15:16:28    INFO                Started ANSYSLI server.
          2022/10/19 15:16:30    CLIENT_CONNECT        1/1/1/1   7228:SPACECLAIM:jocel@BonneJournée:winx64                  7380:10.192.177.151
          2022/10/19 15:16:30    NEW_CONNECTION      Connected to Licensing Client Proxy server: 51079@127.0.0.1.
    • George Karnos
      Exit all ansys programs.
      Try renaming:
      %APPDATA%\Ansys
      to:
      %APPDATA%\Ansys.old
      And:
      %APPDATA%\SpaceClaim
      to:
      %APPDATA%\SpaceClaim.old
      Now try to run.
      • Jocelyn Dubuc
        Just tried this. I am still getting the same error message when I try to launch SpaceClaim.
    • George Karnos
      If this a new installation, I recommend changing the Hostname of the machine...
      BonneJournée  contains a special character and most likely is interferring with license .
      Example... Change from BonneJournée to BonneJournee
      Also, when was this version downloaded?
      Did you download the following version:   2021 R2.1
      • Jocelyn Dubuc
        Ok, I will try changing the hostname and tell you what happens. I downloaded it yesterday (Oct. 18th) to try and see if a fresh install would fix the problem.
      • Jocelyn Dubuc
        Changing the hostname did the trick. Everything seems to work now. Thank you so much for your help!
    • George Karnos
      Also, was there a previous version installed?
      • Jocelyn Dubuc
        I had installed version 2021 R2.1 before but uninstalled to try and see if a fresh install would fix my problem.
Viewing 4 reply threads
