Ansys Products
Ansys Products
Invalid Command [Addon-Module]
    • Gage Gardinier
      Hello!
      I currently have ANSYS installed on my PC and have it linked to a teaching license through my university. I am attempting to do some MHD simulations, but when I go to add the MHD module through /define/models/addon-module, I get the error "Invalid Command [Addon-Module]"
      I have included a screenshot for reference
      Any guidance would be greatly appreciated
      Can you load a mesh in and try again? Are you running 2d, 2ddp, 3d or 3ddp?
    • Gage Gardinier
      Adding a model to the environment fixed the issue. Sorry about that, should have been obvious.
      For posterities sake, I was running 3d
      Thanks Gage. It's only obvious once you've tried it - which I did too as it could have been something else.
      As an aside. Unless you've low on RAM it's generally a good idea to run double precision. It's something that was previously only recommended in certain scenarios but given the power of modern hardware there's very little reason not to now.
Viewing 3 reply threads
