Invalid/missing Stress Life curve
    • AmirulHaziq
      Hi
      I am using Ansys Workbench to calculate the number of cycles till failure for an ankle implant made of CoCrMo and UHMWPE parts. The model is subjected to a 796 N load pointing upwards. I've added the material properties of isotropic elasticity, Young's Modulus, Poisson's Ratio, Ultimate tensile strength and tensile yield strength. However, once I have solved, I get the error- "Invalid or missing stress life curve". Just what exactly am I missing or which parameter is wrong? Any help will be appreciated.
    • SaiD
      Can you check the Materials properties in Mechanical and make sure the S-N curve has been defined? The following post might help:
      https://forum.ansys.com/forums/topic/fatigue-random-vibration-analysis-error-with-stress-life-curve/
      Sai
    • AmirulHaziq
      Yes it works.thank you
