November 9, 2018 at 11:41 am
AndreaM
SubscriberHi, I created an assembly by using PTC CREO, with 2 parts. I saved it as an IGES file and I imported it on Ansys. When I try to analyze it in Static Structural I got "Invalid Volume" as an error. It seems to that Ansys recognizes my model not as a solid but as a set of surfaces.
Thanks for the support!
November 12, 2018 at 7:24 am
Keyur Kanade
Ansys EmployeeYes, you can see those are all surface bodies in model tree.
You need to stitch them together to form a solid body.
Go to Repair tab and use Stitch, gap and missing face option. Have a look at following video.
Keyur Kanade
Ansys EmployeeAlso, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
November 12, 2018 at 6:21 pm
AndreaM
SubscriberThanks kkanade, your link was super-helpful !
November 13, 2018 at 2:54 am
Keyur Kanade
Ansys EmployeeGood that you found it useful.
November 15, 2019 at 8:27 pm
kimant
SubscriberI have the same error "invalid volume" and i don't know why, is there some possibilities for this error? I created a solid body (shaft) in SOLIDWORKS and I saved in Ansys as IGS file and also as STEP file (I tried with both) but it didn't work.
November 15, 2019 at 9:22 pm
SubscriberTry saving as Parasolid from SOLIDWORKS.
November 16, 2019 at 2:13 am
November 16, 2019 at 2:14 am
kimant
Subscriberi got that when i saved as a parasolid
November 16, 2019 at 3:25 am
SubscriberI don't know how you get that error message. It doesn't happen when you Save As a Parasolid from the SOLIDWORKS program, since that is an ANSYS error message.
When you have a Parasolid file, open Workbench and in a New Project, drag out a Geometry component. Start SpaceClaim. In SpaceClaim, do File, Open and set the file type to Parasolid, then point to the file. Close SpaceClaim.
There will be no problem when saving the Workbench file. If there is, put the Parasolid file you saved from SOLIDWORKS into a .zip file and attach that .zip file to your last post and I will have a look.
November 17, 2019 at 5:16 am
kimant
SubscriberIt worked! Thank you
2138
1355
1142
462
