Tagged: coupling, design-optimization, fdtd, optimization, polymer, waveguides
June 28, 2022 at 4:53 am
taige.li
SubscriberHi all,
I tried to optimize a polymer y-branch according to the example here (https://optics.ansys.com/hc/en-us/articles/360042305274).
Since polymer (SU-8) has a much lower refractive index, the main different is the size. I modified all sizes in the base setup .py file and the simulation .py file, yet error occured saying "The initial X is infeasible. Restart with its projection." As a result, the polygon structure extends beyond the bounds defined, and FoM could not be calculated.
Attached please find the screenshot and codes. Please help to check if I made anything wrong.
Thank you very much!
[File 1]
# Scriptfile: y_branch_opt_2D.py
# Description:
# This script sets up and runs the adjoint shape-based optimization for inverse
# design of the SOI Y-branch in 2D
# Steps include:
# 1. Define the base simulation
# 2. Define the optimizable geometry and optimization parameters
# 3. Run optimization
# 4. Save results
# Copyright 2019, Lumerical Solutions, Inc.
# Copyright chriskeraly
import os, sys
import numpy as np
import scipy as sp
import lumapi
from lumopt.utilities.wavelengths import Wavelengths
from lumopt.geometries.polygon import FunctionDefinedPolygon
from lumopt.utilities.materials import Material
from lumopt.figures_of_merit.modematch import ModeMatch
from lumopt.optimizers.generic_optimizers import ScipyOptimizers
from lumopt.optimization import Optimization
######## BASE SIMULATION ########
sys.path.append(os.path.dirname(__file__))
from varFDTD_y_branch import y_branch_init_
y_branch_base = y_branch_init_
######## DIRECTORY FOR GDS EXPORT #########
example_directory = os.getcwd()
######## SPECTRAL RANGE #########
wavelengths = Wavelengths(start = 1530e-9, stop = 1570e-9, points = 21)
######## DEFINE OPTIMIZABLE GEOMETRY ########
# The class FunctionDefinedPolygon needs a parameterized Polygon (with points ordered
# in a counter-clockwise direction). Here the geometry is defined by 10 parameters defining
# the knots of a spline, and the resulting Polygon has 200 edges, making it quite smooth.
# Define the span and number of points
initial_points_x = np.linspace(-12.5e-6, 12.5e-6, 10)
initial_points_y = np.linspace(5e-6, 5e-6, initial_points_x.size)
def splitter(params):
''' Defines a taper where the paramaters are the y coordinates of the nodes of a cubic spline. '''
## Include two set points based on the initial guess. The should attach the optimizeable geometry to the input and output
points_x = np.concatenate(([initial_points_x.min() - 0.01e-6], initial_points_x, [initial_points_x.max() + 0.01e-6]))
points_y = np.concatenate(([initial_points_y.min()], params, [initial_points_y.max()]))
## Up sample the polygon points for a smoother curve. Some care should be taken with interp1d object. Higher degree fit
# "cubic", and "quadratic" can vary outside of the footprint of the optimization. The parameters are bounded, but the
# interpolation points are not. This can be particularly problematic around the set points.
n_interpolation_points = 100
polygon_points_x = np.linspace(min(points_x), max(points_x), n_interpolation_points)
interpolator = sp.interpolate.interp1d(points_x, points_y, kind = 'cubic')
polygon_points_y = interpolator(polygon_points_x)
print(polygon_points_y)
### Zip coordinates into a list of tuples, reflect and reorder. Need to be passed ordered in a CCW sense
polygon_points_up = [(x, y) for x, y in zip(polygon_points_x, polygon_points_y)]
polygon_points_down = [(x, -y) for x, y in zip(polygon_points_x, polygon_points_y)]
polygon_points = np.array(polygon_points_up[::-1] + polygon_points_down)
return polygon_points
# L-BFGS methods allows the parameters to be bound. These should enforse the optimization footprint defined in the setup
bounds = [(0.2e-6, 0.8e-6)] * initial_points_y.size
print("Bounds:")
print(bounds)
#Load from 2D results if availble
try:
prev_results = np.loadtxt('2D_parameters.txt')
except:
print("Couldn't find the file containing 2D optimization parameters. Starting with default parameters")
prev_results = initial_points_y
# Set device and cladding materials, as well as as device layer thickness
eps_in = Material(name = 'SU-8')
eps_out = Material(name = 'air')
depth = 2e-6
# Initialize FunctionDefinedPolygon class
polygon = FunctionDefinedPolygon(func = splitter,
initial_params = prev_results,
bounds = bounds,
z = 0.0,
depth = depth,
eps_out = eps_out, eps_in = eps_in,
edge_precision = 5,
dx = 1.0e-9)
######## FIGURE OF MERIT ########
fom = ModeMatch(monitor_name = 'fom',
mode_number = 'fundamental mode',
direction = 'Forward',
target_T_fwd = lambda wl: np.ones(wl.size),
norm_p = 1)
######## OPTIMIZATION ALGORITHM ########
optimizer = ScipyOptimizers(max_iter = 30,
method = 'L-BFGS-B',
#scaling_factor = scaling_factor,
pgtol = 1.0e-5,
ftol = 1.0e-5,
#target_fom = 0.0,
scale_initial_gradient_to = 0.0)
######## PUT EVERYTHING TOGETHER ########
opt = Optimization(base_script = y_branch_base,
wavelengths = wavelengths,
fom = fom,
geometry = polygon,
optimizer = optimizer,
use_var_fdtd = True,
hide_fdtd_cad = False,
use_deps = True,
plot_history = True,
store_all_simulations = False)
######## RUN THE OPTIMIZATION ########
results = opt.run()
######## SAVE THE BEST PARAMETERS TO FILE ########
np.savetxt('../2D_parameters.txt', results[1])
######## EXPORT OPTIMIZED STRUCTURE TO GDS ########
gds_export_script = str("gds_filename = 'y_branch_2D.gds';" +
"top_cell = 'model';" +
"layer_def = [1, {0}, {1}];".format(-depth/2, depth/2) +
"n_circle = 64;" +
"n_ring = 64;" +
"n_custom = 64;" +
"n_wg = 64;" +
"round_to_nm = 1;" +
"grid = 1e-9;" +
"max_objects = 10000;" +
"Lumerical_GDS_auto_export;")
with lumapi.MODE(hide = False) as mode:
mode.cd(example_directory)
y_branch_init_(mode)
mode.addpoly(vertices = splitter(results[1]))
mode.set('x', 0.0)
mode.set('y', 0.0)
mode.set('z', 0.0)
mode.set('z span', depth)
mode.set('material','SU-8')
mode.save("y_branch_2D_FINAL")
input('Enter...')
mode.eval(gds_export_script)
June 28, 2022 at 4:54 am
taige.li
Subscriber[File 2]
# Python Module: varFDTD_y_branch.py
# Description:
# This module defines the y_brach_init_() function used in the
# optimization for inverse design of the SOI Y-branch in 2D
# Steps include:
# 1. Define the base simulation parameters
# 2. Add non-dispersive materials
# 2. Define the geometry of input and output waveguides
# 3. Set up source and monitors and simulation region
######## IMPORTS ########
# General purpose imports
import lumapi
import numpy as np
from scipy.constants import c
def y_branch_init_(mode):
## CLEAR SESSION
mode.switchtolayout()
mode.selectall()
mode.delete()
## SIM PARAMS
size_x=40e-6;
size_y=20e-6;
mesh_x=200e-9;
mesh_y=200e-9;
finer_mesh_size=19e-6;
mesh_accuracy=4;
lam_c = 1.550e-6;
thickness=2e-6;
separation=5e-6; #waveguide separation
coupler_length=24e-6;
width=2.4e-6; #waveguide
length=10e-6; #connecting waveguide
## MATERIAL
opt_material=mode.addmaterial('Dielectric');
mode.setmaterial(opt_material,'name','Si: non-dispersive');
n_opt = mode.getindex('Si (Silicon) - Palik',c/lam_c);
mode.setmaterial('Si: non-dispersive','Refractive Index',n_opt);
#print(n_opt);
sub_material=mode.addmaterial('Dielectric');
mode.setmaterial(sub_material,'name','SiO2: non-dispersive');
n_sub = mode.getindex('SiO2 (Glass) - Palik',c/lam_c);
mode.setmaterial('SiO2: non-dispersive','Refractive Index',n_sub);
mode.setmaterial('SiO2: non-dispersive',"color", np.array([0, 0, 0, 0]));
air_material=mode.addmaterial('Dielectric');
mode.setmaterial(opt_material,'name','air');
mode.setmaterial('air','Refractive Index',1);
wg_material=mode.addmaterial('Dielectric');
mode.setmaterial(opt_material,'name','SU-8');
mode.setmaterial('SU-8','Refractive Index',1.573);
## GEOMETRY
#INPUT WAVEGUIDE
mode.addrect();
mode.set('name','input wg');
mode.set('x span',10e-6);
mode.set('y span',width);
mode.set('z span',thickness);
mode.set('y',-separation/2);
mode.set('x',-coupler_length/2-length/2);
mode.set('z',0);
mode.set('material','SU-8');
mode.addrect();
mode.set('name','input wg 2');
mode.set('y',separation/2);
mode.set('z',0);
#OUTPUT WAVEGUIDES
mode.addrect();
mode.set('name','output wg top');
mode.set('x',coupler_length/2+length/2);
mode.set('z',0);
mode.addrect();
mode.set('name','output wg bottom');
mode.set('z',0);
mode.addrect();
mode.set('name','sub');
mode.set('x span',100e-6);
mode.set('y span',100e-6);
mode.set('z span',10e-6);
mode.set('y',0);
mode.set('x',0);
mode.set('z',0);
mode.set('material','SiO2: non-dispersive');
mode.set('override mesh order from material database',1);
mode.set('mesh order',3);
mode.set('alpha',0.8);
## varFDTD
mode.addvarfdtd();
mode.set('mesh accuracy',mesh_accuracy);
mode.set('x min',-size_x/2);
mode.set('x max',size_x/2);
mode.set('y min',-size_y/2);
mode.set('y max',size_y/2);
mode.set('z',0);
mode.set('z span',4e-6);
mode.set('effective index method','variational');
mode.set('can optimize mesh algorithm for extruded structures',1);
mode.set('clamp values to physical material properties',1);
mode.set('x0',-1.3e-6);
mode.set('number of test points',4);
mode.set('test points',np.array([[0, 0],[1.3e-6, 0.4e-6], [1.3e-6, -0.4e-6], [1.3e-6, 0]]));
## SOURCE
mode.addmodesource();
mode.set('direction','Forward');
mode.set('injection axis','x-axis');
#mode.set('polarization angle',0);
mode.set("y span",width);
mode.set('x',-coupler_length/2-5e-6);
mode.set('center wavelength',1550e-9);
mode.set('wavelength span',0);
mode.set('mode selection','fundamental mode');
## MESH IN OPTIMIZABLE REGION
mode.addmesh();
mode.set('x',0);
mode.set('x span',finer_mesh_size);
mode.set('y',0);
mode.set('y span',finer_mesh_size);
mode.set('dx',mesh_x);
mode.set('dy',mesh_y);
## OPTIMIZATION FIELDS MONITOR IN OPTIMIZABLE REGION
mode.addpower();
mode.set('name','opt_fields');
mode.set('monitor type','2D Z-normal');
mode.set('x',0);
mode.set('x span',0.95*size_x);
mode.set('y',0);
mode.set('y span',0.95* size_y);
mode.set('z',0);
## FOM FIELDS
mode.addpower();
mode.set('name','fom');
mode.set('monitor type','Linear Y');
mode.set('x',coupler_length/2+1.5e-6);
mode.set('y',0);
mode.set('y span',size_y);
mode.set('z',0);
if __name__ == "__main__":
mode = lumapi.MODE(hide = False)
input('Press Enter to escape...')
July 23, 2022 at 12:01 am
Guilin Sun
Ansys EmployeeI just found your post which is in the wrong forum. Lumerical has dedicated English, Chinese and Korean forums:
https://forum.ansys.com/forums/forum/discuss-simulation/photonics/
https://forum.ansys.com/forums/forum/discuss-simulation/photonics/photonics-chinese/
https://forum.ansys.com/forums/forum/discuss-simulation/photonics/photonics-korean/
Next time please post in the proper forum in order to get quick reply.
You may find more resources online https://github.com/chriskeraly/BerkeleyPhotonicInverseDesign
I would recommend that you modify the structure gradually one by one from small changes. Before you are skillful, please follow the examples, do minor change and see what happens.
Please write new post in the correct forum if you have questions.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- How to calculate the cross-polarization efficiency and phase in FDTD
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2598
2082
1317
1108
459
