December 27, 2021 at 6:32 am
mohitkhurana
SubscriberCONFIGURATION FILE {'root': 'C:\Program Files\Lumerical\v212\api\python', 'lumapi': 'C:\Program Files\Lumerical\v212\api\python'}
Initializing super optimization
Checking for one forward simulation : More than One Wavelengths range, one forward simulation is not possible
Wavelength range of source object will be superseded by the global settings.
Traceback (most recent call last):
File "C:UsersakimoDropboxMohitJupyter-labfilterLumerical_scripting1Input_1Outputfilter_opt_3D_TE_topology_minfeaturesize.py", line 88, in
runSim(startingParams, eps_bg, eps_wg, x_pos, y_pos, z_pos, filter_R=filter_R, min_feature_size=min_feature_size, working_dir=working_dir, beta = startingBeta)
File "C:UsersakimoDropboxMohitJupyter-labfilterLumerical_scripting1Input_1Outputfilter_opt_3D_TE_topology_minfeaturesize.py", line 59, in runSim
opt.run(working_dir = working_dir)
File "C:Program FilesLumericalv212apipythonlumoptoptimization.py", line 460, in run
self.initialize(working_dir=working_dir)
File "C:Program FilesLumericalv212apipythonlumoptoptimization.py", line 141, in initialize
list(map(init_suboptimization, self.optimizations))
File "C:Program FilesLumericalv212apipythonlumoptoptimization.py", line 137, in init_suboptimization
cur_optimization.initialize(local_working_dir)
File "C:Program FilesLumericalv212apipythonlumoptoptimization.py", line 667, in initialize
self.geometry.add_geo(self.sim, start_params, only_update = False)
File "C:Program FilesLumericalv212apipythonlumoptgeometries opology.py", line 554, in add_geo
self.check_param_count_matches_sim_eps(params, sim)
File "C:Program FilesLumericalv212apipythonlumoptgeometries opology.py", line 165, in check_param_count_matches_sim_eps
". This can occur when the initial condition specified to LumOpt do not match the dimensions of the FDTD grid.")
UserWarning: Project file index monitor reports 1 coordinates, where expected 22801. This can occur when the initial condition specified to LumOpt do not match the dimensions of the FDTD grid.
March 9, 2022 at 1:56 pmm.su
SubscriberI have same problem when I tried to try the code in a new computer. But the same code actually works for my old computer. No idea how to deal with it. Have you solved the issue?
March 9, 2022 at 6:22 pmGuilin Sun
Ansys EmployeeThe reply to this post is here Inverse design python script error
Please do not follow up this post any more.
- Error on Lumerical device
2666
2120
1349
1132
461
