3D Design
3D Design
Inverse/Unselect Geometry(Edge/Face/Solid)
    • sathya
      Hi ,
      Is there any way to reverse/inverse select geometries in DM or Mechaniccal ?
      Ex:
      I want to select 90 faces out of 100.
      Instead of selecting all faces and deselecting 10,can I select 10 and inverse select remaining 90 faces?
    • Keyur Kanade
      use right click and select all.
      then use left mouse button and ctrl to deselect 10 faces.
    • sathya
      Read the query again.
      I dont want to use the usual approach.I want the alternate.
    • Keyur Kanade
      sorry, but there is no alternate option as such.
      you will have to follow the method which i mentioned in previous post for selecting required 90 faces.
    • kaitova
      this function just appeared to me now, it exists, hurray!
    • kaitova
    • Keyur Kanade
      good. can you please mark this as 'is solution' to help others on the community.
      Keyur
Viewing 6 reply threads
