March 23, 2022 at 10:24 am
ray1989
SubscriberI was able to open the dat flies yesterday. Today it's showing this error.
Error: Unable to open D:/PHD/Thesis chapter s/Inclination chapter/Eccentric tube/Charging/Right_eccentric/Mesh_independence/312948_elements/HPC/D_PHDThesis chapter sInclination chapterOnly vertical modelEccentric tube3D_eccentric_horizontal_filesdp0FFF-5FluentFFF-5.1-10-3600.dat.h5 for reading.: iostream stream error
Error Object: #f
Could anyone please suggest how to resolve the issue?
Thanks
Alok Ray
March 23, 2022 at 1:05 pmKR
AdministratorHello Do you have any special characters (such as $ or ' etc.) used in the folder names? If so, could you please rename your folders and try again?
Karthik
March 23, 2022 at 5:04 pmray1989
SubscriberNo. I don't have any special character in the folder name.
Thanks
Alok
March 23, 2022 at 5:15 pmGeorge Karnos
Ansys EmployeeWhat happens if you shorten the name of everything..
Use D:\PHD\Test
and shorten the name of the file from D_PHDThesis chapter sInclination chapterOnly vertical modelEccentric tube3D_eccentric_horizontal_filesdp0FFF-5FluentFFF-5.1-10-3600.dat.h5
to test.dat.h5
March 24, 2022 at 9:21 amray1989
SubscriberIt worked. Thank you
March 24, 2022 at 12:11 pmGeorge Karnos
Ansys EmployeeExcellent!
You are Welcome!
October 1, 2023 at 3:45 pmSY
SubscriberMaybe this will help others. I did get the same error message but could just fix it by deactivating the usage of CFF-File-Format using the command line
”file/cff-files? no”. See also: Fluent 2020R1 > Fluent User’s Guide > 3.3.4. Reading and Writing Files in the Legacy Format
Context: I had an old simulation with 40 time steps that was simulated using ANSYS Fluent 2020R1 and the results were saved as .cas.gz and .dat.gz . When I tried to extend the calculation for 40 more time steps in a newer Version or even in ANSYS Fluent 2020R1 Fluent tries to use the .cas.h5 and .dat.h5 formats. This can be suppressed with the command above for the present Session only or also for future Sessions via the preferences, see User’s Guide entry above. Now, the extended calculation saves every time step in the old/legacy format, without error messages.
This is also helpful, because I can now use CFD-Post to have it read all time steps and generate Animation sequences from it. The features that Fluent offers are not sufficient in my case.
Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Not seeing any items in the ANSYS Workbench toolbox?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
- Acoustics model in Ansys 18.1
7818
4514
2979
1453
1322
