April 14, 2022 at 7:25 am
Ak0703
SubscriberHi
I was wondering whether design modeler is stopped in 2022 R1 I couldn't find it when i right click geometry
There are only two options one is spaceclaim and other is Discovery
April 14, 2022 at 9:36 amVinayak Vipradas
Design Modeler is available for Ansys 2022 R1.
If you are having trouble accessing it, please refer to the following post:
Howto install DesignModeler? ÔÇö Ansys Learning Forum
Regards Vinayak
Ansys Help
Rules & Guidelines ÔÇö Ansys Learning Forum
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
